Vibration at highway speeds.
Old 03-31-2015, 10:01 AM
stu37d's Avatar
stu37d
stu37d is offline
Government Teat-sucker
Wow, thread mining! I fixed the problem by trading the truck in on a 2012 F250 6.7l
  #32
Old 04-21-2015, 07:33 AM
Fe_Giraffe's Avatar
Fe_Giraffe
Fe_Giraffe is offline
Recently purchased a 2008 F150 fx4 with 100k miles on it and have been experiencing shaking in the steering wheel and throughout the cab at highway speeds. It isn't every time but often enough. I'm also getting a lot of break dust buildup on my front driver's side - much more than on any other tire. Any relation to the wobble or do I have two separate issues?
  #33
Old 04-21-2015, 10:42 AM
1saxman's Avatar
1saxman
1saxman is offline
It gets more complicated with 4WD, but still, most front end shimmy is related to wheel balance or bad tires. Bent wheels can be responsible too. One clue is interesting - the brake dust. You could have a caliper on that wheel that is sometimes not fully releasing. The rotor may also be a little warped, causing the chatter. You could have a combination of all those things on the front axle, and considering 4WD, there are more possibilities.
  #34
Old 04-21-2015, 11:10 AM
Fe_Giraffe's Avatar
Fe_Giraffe
Thanks for the reply. Given that it's my first truck and I haven't had it very long I wanted to get some idea of what the problem might be before taking it to the shop and having a mechanic look at it.
Strange that I don't have any squealing in the breaks or other steering issues besides the shaking at 50-70mph. I've only used it once, but the parking brake nearly got stuck - took me awhile to get it to let go and when I did the light remained on in dash for several days. I'll start with balancing the tires and getting the brakes checked and see if that doesn't clear things up. Appreciate the help!
  #35
Old 04-29-2015, 10:58 AM
Chariotz's Avatar
Chariotz
Chariotz is offline
Originally Posted by stu37d
Alrighty. I did a cursory search and couldn't find a related link, so thought I'd start a thread about this.
My 2005 FX4 has a vibration when it gets over about 50mph. I can feel it in the steering wheel, and throughout the cab as well. It steers straight even with the vibration. What could this be?
Possibly brakes or needs alignment is what it sounded like..
It could be wayyyyy worse!
________________________________________
See this entire project of one of our feature pages on www.Chariotz.com
Check out this link for more information and download our FREE 'Chariotz' app on the iTunes store here.
Rick Martinez - @Rick_Raspberry
Car Enthusiasts check us out!
Website: Chariotz
Facebook: Chariotzinc
Instagram: @Chariotzinc
Twitter: @ChariotzINC
Download our FREE app in the iTunes store here
  #36
Old 04-29-2015, 11:53 AM
Fe_Giraffe's Avatar
Fe_Giraffe
I had a seized caliper on my front passenger tire that was causing most of the problem. Pads, rotors, and brake lines were bad. Needed about $1500 of work to repair/replace everything needed. Wasn't happy about it but it rides smoothly now. Worth contacting the dealer I bought it from to complain about a malfunction like this 3 months after purchase?
  #37
Old 05-03-2015, 11:02 AM
Black Helmet's Avatar
Black Helmet
Black Helmet is offline
I had a similar issue a year ago or so on my 2005, parking brake stuck GOOD lol. Luckily no real damage, just needed a thorough cleaning.
  #38
Old 07-18-2019, 01:00 PM
Tatt2rich's Avatar
Tatt2rich
Tatt2rich is offline
98 f150 shakes at 65
So i bout a 98 f150 shakes at 65 bought new tires balanced still shakes at highway speeds. No leaks on rearend or anything
  #39
Old 07-19-2019, 03:18 PM
1saxman's Avatar
1saxman
1saxman is offline
Well, I had a buddy balance my tires and found that the right front was pretty badly out of balance. The other three were a half ounce or so, but the right front was 5.5 in one spot, 3 oz in another and a couple of little 1/4 ouncers. He got it balanced out, though. I was only able to get the truck up to about 60 and only for about 20 seconds, but I felt no vibration at all. I'll get it up to about 70 or so on the freeway in the morning, so I'll know a little more then. I'm guessing that right front is slightly bent?
The right front was badly out of balance - why would it be bent if the balancing solved the problem?
  #40
Old 07-19-2019, 03:21 PM
1saxman's Avatar
1saxman
1saxman is offline
Originally Posted by afc2001
Just had my oil changed and tires rotated. had speed wobble (as i call it) and thought it was tires out of balance. went to my buddies shop and they were just fine. we started poking around and noticed quite a bit of play in the upper ball joints. Took truck to the dealer and both upper ball joints are shot. good thing i decided to check it out before the warrenty runs out (3000 km to go).
Are you in the right forum? 2004-2008 F150s have struts.
ExcursionQ13
05-24-2016 09:22 PM
Pool Runner
2009 - 2014 F150
03-22-2012 10:00 AM
Golfmore
10-31-2005 11:45 AM
Triboy
1997-2006 Expedition & Navigator
03-14-2005 08:03 PM
GLakes
2004 - 2008 F150
07-25-2004 12:56 AM
Quick Reply: Vibration at highway speeds.
