Up and Runiing Again.( Brake Line)In-Tank Mod's
Well 2 days later I am Back and running or should I say Stopping Again.. I Had to buy 3 sections of line in order to do it,12ft 3 inches.. and a hell of a lot of bends.. I put the old line in a vise laid new line over it and started bending.. I Dont wish that on anyone.. anyhow I went ahead and did the in-tank mod's while I had the tank out..I got all the items from different stores here spent around $90.00 made my Bracket ,and all mounted up and running.. something I did do is before the final Hose connection at the pump, I filled a Quart oil bottle with diesel, put a nipple from a 90wt bottle on it and forced the diesel back thru the filter to the tank.. I did this till All the Air was out of the line,then slipped line back on pump..
I cycled the key several times, and the ole girl is purrin like a kitten, either my hearing is going south or the truck is running quieter all ready.. no problems what so ever. Thanks FTE for all the Info needed to do such mod's..
