2006 lexington rv w/v10
To the OP, don't know the answer as I own neither a V10 nor a motor-home. I do know that it a popular engine choice in gas-powered MH's. Should do just fine, you just won't win any races with it. I would say 6-8 mpg would be reasonable. Maybe a little better on the flats, little less in the hilly areas. And there are things you can do to tweak it. Headers, tuner from 5-star. Should make it more responsive, improve tranny shifting.
Everybody's definition of "comfortable" is different...
My truck and bumper pull trailer weighed in at just under 18K on our last trip. We had no problem keeping up with any traffic, and could comfortably do 55 over Siskiyou Summit on I-5. Able to do Donner on I-80 at over 50 with similar load. We pass at least 30 rigs for every one that passes us... I consider it very comfortable and would not hesitate to pull another couple tons.
This is with mildly modified 2V PI. If this RV is a Class A, it would be 3V and have even more power.
My rig normally gets between 7 and 9 while cruising at 55-60. A motor home should be more aerodynamic and have less rolling resistance, so I would expect 8 to 10 if you drive like we do. MPG is extremely speed related. I can get it down to 5 if I push it up to 70...
2006, 2006lexington, 2007, 23, archive, bed, comfortable, forest, lexington, mh, motorhome, motorhomes, mpg, river, specifications
