Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
2011 F350 SRW Tire dip issue..Anyone Else?
Old 07-22-2010, 07:28 PM
rsyauto
rsyauto is offline
rsyauto is starting off with a positive reputation.
At 2100 miles my front tires are dipping/cupping on the inner side..265/75/20 Mich. tires...Anyone else having this issue? Thanks
Old 07-22-2010, 08:10 PM
shelbymustang
shelbymustang is offline
shelbymustang is starting off with a positive reputation.
sounds like bad shocks
Old 07-22-2010, 08:14 PM
rsyauto
rsyauto is offline
On brand new truck....? really?
Old 08-08-2010, 12:27 PM
GMUGNIER
GMUGNIER is offline
GMUGNIER is starting off with a positive reputation.
Yea mine too - But it is on all four tires.
Old 08-08-2010, 02:33 PM
Cerb
Cerb is offline
Cerb is starting off with a positive reputation.
Ford had to replace all four of my shocks with only 1100 miles on the truck. Appearantly there were bad welds inside the shocks that broke and may the bouncy. Got new shocks and problem went away, my service guy did tell me that a TRB went out about the shock issue.
Old 08-08-2010, 05:34 PM
Champ198
Champ198 is offline
Champ198 is starting off with a positive reputation.
I have the same exact tires on my truck. I had my tires rotated (first rotation) and the front tires have been wearing funny and feathering as well. I had my alignment checked and it was barely out, actually still in spec. The guy at discount tire said that the front tires appear to do that on the SuperDuty trucks, especially on one side, and doesn't know why. I believe that Ford has the door air pressure plate (65lbs on my truck) set too low. I'm keeping at least 70lbs in them.
Old 08-08-2010, 06:42 PM
GMUGNIER
GMUGNIER is offline
Well did the TSB address the tires that may be ruined and diminished tire life - These tires are only 360.00 a PIECE!!! hope fully they will address both concerns at the same time.
Old 08-08-2010, 11:03 PM
F700Tank's Avatar
F700Tank
F700Tank is offline
F700Tank is starting off with a positive reputation.
2700 miles on my Mich 265/75/20's. Haven't noticed any problems but will be keeping a closer look.
Old 08-09-2010, 08:10 AM
rickatic
rickatic is offline
rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.
Same here. 6800 and I went out and looked at them this morning. Good so far.
Old 08-09-2010, 10:26 AM
GMUGNIER
GMUGNIER is offline
Run your hand over the tread you will feel the uneven wear - you cannot see it unless it is very pronounced - (Note: when you are running your hand over the tread pay special note to the tread patch itself - when properly alligned and no problems it will feel perfectly flat for the most part - however when the tire has issues you feel the difference.
Old 08-09-2010, 10:49 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
It can be alignment, worn suspension parts, shocks or balance. You have 2 conditions of balance, lateral and radial, which typically will show spots of wear or cupping not all the way around the tire.
Since the truck is new, move the effected tires to the rear, check alignment and replace the shocks since that seems to be the logical part in question. Be nice to your dealer and see if you as a group can find a solution.
Old 08-09-2010, 10:52 AM
Maxium4x4's Avatar
Maxium4x4
Is the wear pattern even all around on one side of the tire or in spots?
Old 08-09-2010, 11:18 AM
rickatic
rickatic is offline
When I ran my hand over the tire I thought, I heard the truck purr. Tires were fine though
BullsOnParade88
1997 - 2003 F150
12-02-2014 03:58 PM
yfz 450
29
11-11-2014 09:57 AM
EP145
12-13-2013 02:57 PM
89Bulldog
Ranger & B-Series
07-28-2010 09:01 PM
madmax99
6.4L Power Stroke Diesel
15
06-14-2009 07:25 PM
Quick Reply: 2011 F350 SRW Tire dip issue..Anyone Else?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
