1961 f100
1961 f100
hi
in the last week i buy 2 ford f 100
1980 costume
and 61 ford f 100 ( but the seller told me that is ranchero 57 )
what can you tell me about the truck ?
i need to know where is the vin number ?
what kind of rear end i have > ( it dosent look like my 8 inch in my 67 mustang ) ?
1980 costume
~ 1961 Uni-Body ~
Welcome to FTE
The 9" rear axle used in 1957/86 F100's is a larger version of the 8" rear axle used in Mustangs. They look very similar.
1959/67 F100: If Limited Slip was ordered, these truck have a Spicer-Dana 44 rear axle which has an inspection cover at the rear of the housing.
The VIN will be stamped on the top of the right (passenger) side frame rail just in front of or partially under the cab.
The VIN will also be found on the Warranty Plate which is located on trucks of this vintage, on the inside of the glove box door.
However, I do not see it on the glove box door in the above pic. It's either missing, or the truck is a 1963.
1963 and later: The Warranty Plate is located on the face of the left front door below the latch.
While the grille is a 1961, any 1961/66 grille will bolt right in. Uni-Body Styleside pickups were made from 1961 thru midyear 1963.
It has Volare front suspension.
1961 f100 cancer
my f100 is dying of a slow rot i just saw a bubble in the cab channel and found that it is rotted all the way through to the inside does anyone know where i can find a replacment cab or have channels fabricated ty p.s. also looking for new hood kids in neighbor hood sat on the hood and bent the supports
bradford237
28
04-08-2013 06:51 PM
bob_351
02-22-2010 02:47 AM
aguitarestv
18
06-10-2009 08:26 AM
