Doesn't appear to be leaking from rad or any hoses or overflow tank,it leaks right out the bottom,it started as a slow leak,had to add coolant once every 2 weeks. now it's about once a week. As the budget for this repair is $0 right now,was wondering if anybody has ever used Rislone copper block sealer or any similar products with any success.Thanks
Did he show you the hose by any chance? And did he mention any other hoses that ought to be replaced. I replace stuff like that as a set, assuming they're originals.
PS: glad you got it fixed. That was an easy one.
The only other one he noticed was a cracked pcv hose. Changing them all sounds like a good idea though, gonna do the ones I can get at myself.
