Spare Tire Question
Old Jul 20, 2010 | 10:30 AM
BrianFX4's Avatar
BrianFX4
Spare Tire Question
Hey guys just wondering about something and hoping you can help me.
I currently have 325/60R18s on my 09 F150 FX4 with a 2.5" LK. As of right now I have the stock 275/70R17 as a spare. I know that sounds weird to go to 18s from a 17 but the aftermarket 18s came off my old 2004 F150 that came stock with 18s.
Anyway my question is if I needed to use that spare would it work as far as my Trac Control and crap like that? Would it cause my roll stability and trac control to kick on even going in a straight line? Would it tear up a bunch of stuff?
Last question should I get a new spare that has an 18" rim and if so how small of a tire could I get away with as I do not want to carry around a 5th 325/60.
Thanks.
Old Jul 20, 2010 | 03:20 PM
shotgunz's Avatar
shotgunz
325/60R18 = 33.354" diameter 605 revs/mile (unloaded)
275/70R17 = 32.157" diameter, 627 revs/mile (unloaded)
9.65% difference.
This is just a guess, but I'd say you're going to have issues.
A 295/70R17 = 33.26" diameter 606 revs/mile (unloaded) should work for a spare.
Old Jul 20, 2010 | 04:48 PM
BrianFX4's Avatar
BrianFX4
Yeah I agree. It just hit me this morning on my way to work that my spare is basically a doughnut compared to the tires I run on it. At least if I go with your suggestion I wouldn't have to buy another wheel just a bigger tire.
Do you think that 295 would still fit under the truck where the spare is now?
Old Jul 20, 2010 | 06:27 PM
shotgunz's Avatar
shotgunz
Well, the 295 is only 1.1" larger (diameter). You could crawl underneath and see if there's a 1/2" space all the way around.
Or you could go find a cheap used 295 (junkyard), get it mounted, and try it out.
Old Jul 20, 2010 | 09:08 PM
Ryan50hrl's Avatar
Ryan50hrl
You don't really have to go to an 18 inch wheel if you can find a tire thats the same diameter and rev/mile ......thats all thats important for a spare
Old Jul 21, 2010 | 06:53 AM
shotgunz's Avatar
shotgunz
I agree. His existing spare is a 17".
Old Jul 21, 2010 | 08:21 AM
BrianFX4's Avatar
BrianFX4
Cool thanks guys I appreciate it. I'll start hunting for a cheap spare now.
Old Jul 21, 2010 | 08:33 AM
BrianFX4's Avatar
BrianFX4
OK I did some quick checking real fast on the Nitto website, not saying I'll buy the Nitto as a spare just using the site as research.
This is what I found according to their specs.
Currently on truck:
325/60R18 = 32.99 x 12.83 Rev/Mile 630
Possible spare sizes
295/70R17 = 33.19 x 12.13 Rev/Mile 626
285/70R17 = 32.72 x 11.46 Rev/Mile 635
Based on that data would the 285 work? I ask as I have a feeling the 285 size would be cheaper than the 295.
Again thanks for the help guys.
Old Jul 21, 2010 | 09:23 AM
shotgunz's Avatar
shotgunz
Currently on truck:
Possible spares:
The values from Nitto's site must include some squish/loading in the diameter calculation (or their tires do not follow the metric sizing 'perfectly').
Regardless, as long as it's temporary, I doubt the 5 revs/mile difference would cause any issues.
Old Jul 22, 2010 | 06:29 AM
tvsjr's Avatar
tvsjr
Unless you have an exact match, you'll need to only mount the spare on a front wheel. If you have a flat on the rear, move a front tire back and mount the spare up front. That will save your rear end from chattering/binding due to unequal tires.
Old Jul 23, 2010 | 02:56 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
And burning up. Agreed with moving the spare to the front, more work but you wouldn't puke the rear. I wouldn't take the chance, unless you get the bigger and let a little air out of it so its the same height, that could possibly work, no?
Old Jul 24, 2010 | 02:26 PM
tvsjr's Avatar
tvsjr
It could, if you want to carry tools to measure down to a few hundredths of an inch to make sure!
Move the spare to the front, don't engage 4WD, and drive it easy (keep in mind you'll still have ABS challenges due to unequal front wheel speeds) to a tire shop. Or carry a matching spare...
Old Jul 24, 2010 | 06:31 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
This is the best thing to do I agree.
Jbhawx
2009 - 2014 F150
Jan 16, 2017 12:28 AM
BlackHogDown
17
Apr 6, 2016 12:29 PM
dieselsmoker
6.7L Power Stroke Diesel
Oct 26, 2015 11:01 PM
YooperUno
2009 - 2014 F150
Oct 9, 2013 10:15 AM
dnelson82
2004 - 2008 F150
17
Aug 4, 2006 07:37 PM
