If you're going to build a fire-breather, that would be a good carb, if in good condition. Is it a double pumper, mechanical secondaries? I haven't looked at carbs for years, and never at that particular one. Several other guys here will know just by hearing the model if not looking at the picture.
If you are going to cash in on your load of collectibles, then the carb goes along with the other racer stuff.
Vacuum secondaries. Here is where I got the information.
Travel, I'd be buying some lottery tickets if i were you. That fellow is more than just giving you a heck of a deal, he is paying you to take the stuff. Those blocks, in standard bore with some taper, ....4,000$. The heads, 1k each. This guy must really, REALLY like you. I'm stunned. keep us posted on what you deciede to build. DinosaurFan
Reason: spelling
