Does it matter which way my rear driveshaft goes in?
Old 07-18-2010, 08:30 PM
BearFootCustom's Avatar
BearFootCustom
BearFootCustom is offline
BearFootCustom is starting off with a positive reputation.
My first time doing u joints and I forgot which way the axle goes...Thanks
Old 07-18-2010, 08:39 PM
jas88's Avatar
jas88
jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
The slip joint goes closest to the transmission.
Old 07-18-2010, 08:44 PM
BearFootCustom
Ya I know that but I took it off the shaft and was wondering if it matters what side it goes on
Old 07-18-2010, 09:52 PM
F100classics
F100classics is offline
F100classics is starting off with a positive reputation.
That is why you mark the two pieces before you take them apart. They need to be put back together "in phase", meaning the two yokes at opposite ends are parallel to each other. This will balance the shaft while it spins otherwise it may wobble.
Old 07-19-2010, 03:49 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
It should go back the way it was when removed. I would have marked it as well.
Look on the driveshaft for stripes. Mine has 4 on the front and 2 on the back.
Old 07-19-2010, 08:43 AM
rla2005's Avatar
rla2005
rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Ironic you would ask this question. After reading several replies I went out to my '92 F-350 to take a look see...lo and behold the front drive shaft is clock 90 degrees out of phase. The yokes do not line up with each other. The rear is good, one piece hard to screw up! Looks like someone in the past has committed a mechanical sin.
This photo from Pirate 4X4 is a good example of correct (top) and incorrect (bottom) orientation:
That was clipped from this article: Driveshaft 401
Old 05-07-2019, 03:15 PM
Lukas Nicolay's Avatar
Lukas Nicolay
Lukas Nicolay is offline
Lukas Nicolay is starting off with a positive reputation.
Slip joints always go to power input side
Old 05-07-2019, 06:38 PM
Pickledboater's Avatar
Pickledboater
Pickledboater is offline
Pickledboater has a good reputation on FTE.Pickledboater has a good reputation on FTE.Pickledboater has a good reputation on FTE.
+1 on clocking it correctly.
Old 05-08-2019, 09:12 AM
jas88's Avatar
jas88
jas88 is offline
Probably much less of an issue being out of phase on the front vs. the rear driveshaft, tho.
78 f150 400
02-22-2017 10:56 PM
Christopher Layton
10-21-2015 10:32 PM
Carmax
13
08-19-2015 02:41 PM
cabloom300
11-10-2013 06:26 PM
ceetwarrior
1947 and Older Ford Trucks
02-01-2007 09:55 PM
Quick Reply: Does it matter which way my rear driveshaft goes in?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
