Replaced ICP and still a check engine light
I have a 2003 F-250 Super duty 4x4 Crew cab w/4" lift and 35" tires.
I replaced the ICP sensor and the connector. I checked all three wires to ground all checked good. I took the check engine light 172 mi to go off. At 200 mi after replacing the sensor and connector the light came back on, put it on code reader and it is still saying ICP sensor/ICP circuit interuption. Has anyone had similar issues, or can someone tell me where to start.
thanks
thanks
Okay I will give it a shot, but this is the 03 6.0. It is on the back of the block below the turbo, I was able to feel my way around to disconnect and remove the sensor. inserting the needles into each wire at the connector will be a challenge. Also just ran to the store the check engine light is going off an on. It will go out for about 3mi, then will come back on. This has happened twice now. thanks for your time
on
ya being an 03 it would be best if you could moniter it vs. sticking it with pins.
the issue with probing a harness such as this is that there very high voltage and current so its important that you know exactly what you are playing with. the good side is thats all in the injector harness so stay away from those wires.
The Solar Guy
03-25-2015 01:45 PM
