coverting my 93 to 134a what type of oil is best? - Ford Truck Enthusiasts Forums
Old 07-16-2010, 07:34 AM
shuttlevalve
shuttlevalve is offline
shuttlevalve is starting off with a positive reputation.
Well the title says it all, but i just about have all the parts to start my convertion new hose off the compressor, accumulator, and red orfice the only major part iam missing is the new compressor that i'm getting next payday. I have enough 134 for the job and gages i just see a few options for oils (PAG?? Ester?? etc) in various weights whats the best for a old converted ford?
Old 07-16-2010, 07:59 AM
GlennFordx4's Avatar
GlennFordx4
GlennFordx4 is offline
GlennFordx4 is gaining momentum as a positive member of FTE.
I used ester when I did mine in my 93 bronco.
Glenn
Old 07-16-2010, 08:01 AM
rla2005's Avatar
rla2005
rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
PAG46 is the most common oil used by Ford for R-134a systems.
Old 07-16-2010, 09:58 AM
fordman1090
fordman1090 is offline
fordman1090 is starting off with a positive reputation.
I used PAG46. And it worked great, however the compressor will come with oil as well, but the oil depends on the freon your using so use accordingly.
It looks like you have most of the stuff ready to go, make sure to pre-fill the compressor and the dryer then put whats left of the oil in the line leading to the compressor.
Make sure the system is completely dry of all old oil and Freon, and run some flush through it. Even if most parts are new. Did the old compressor lock up or stop working? If so you really need to flush or replace the condenser in front of the radiator really well. The older compressors have nylon bushing that wear out, melt and plug the tiny holes in the condenser, then it only causes more problems in the future.
Old 07-16-2010, 02:31 PM
shuttlevalve
No, the system lost charge and the compressor was weeping oil from the halves and the line was leaking off the back of the compressor. whats the best method to flush the condensor and evap?? and make sure all the cleaning agent is out before i charge up the system?
Old 07-16-2010, 02:37 PM
rla2005's Avatar
rla2005
rla2005 is offline
Interesting reading on this topic here: Auto A/C Flush Procedure
Old 07-16-2010, 03:14 PM
fordman1090
I just bought a pressurized can of A/C flush. Then used compressed air to blow/dry it out of the system. Then pull a vac for 20-30min to get all the moisture left by compressed air out, then let it sit for 20-30min at a vacuum to make sure there are no leaks. Then charge.
tkerkela
09-16-2016 12:25 PM
WA0GMH
10-08-2015 10:13 AM
Akzep69
1978 - 1996 Big Bronco
06-20-2015 04:07 PM
kc5hwb
11-03-2011 01:54 PM
shuttlevalve
07-10-2010 10:01 PM
Quick Reply: coverting my 93 to 134a what type of oil is best?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
