Which 8 Lug Wheels will fit a Dent?
Ford used 8 on 6.5 from beginning of time till 97.
Ford went to thee metrick 8 on 170mm in 99(the superduty)
If you noticed there were no such thing as a 8 lug 98
Chevy is 8 on 6.5 bolt pattern but their center huba on a 88 to current are typically small.
Dodge used a 8 on 6.5 patten as well. Their hub center i have never run into an issue.
Aftermarket wheels typicall have a big enough center hub to fit the big 3
Ok thanks I will check bout getting them. On the wheels does it matter if they are steel or Alum.? I was told that steel wheels are best for towing & hauling & that Alum. wheels can't handle the weight. A tire store in town told me the Alum. wheels are for looks only an can't handle the weight on a heavy tow or heavy hauling that steel OEM wheels were the best to go.
I once had a heck of a time getting a set of Chevy (or was it Dodge?) rims to fit over the front hubs of my highboy Fun Fun Fun... back to the junkyard I went.
on
Ford wheels changed over time with most notibly how the wheel covers and hub caps attach for example, but the bolt pattern remained the same untill it changed in 1997/1998.
Typically these years are interchangeable 8 Lug on 6.5.
Going from memory...
1948-1952 F-2 and F-3.
1953-1956 F-250 and F-350 (Has clips to hold hub caps)
1957-1996 F-250 and F-350 (Has dimples to hold the hub caps)
1997 F-250HD and F-350
The 1997 F-250 (Non-HD) and 1998 and newer has metric wheels and will not work.
on
The last Major Redesign of the Econoline Van was in 1992. It's due again as that was 18 years ago now.
The 1975-1991 Econoline was based on the 1973-1979 pickup design, and lasted 16 years with a lot of swappable parts.
