Aerostar Ford Aerostar
97 Aerostar Radiator problems
Old Jul 12, 2010 | 04:34 PM
95TBird's Avatar
95TBird
Well, while I was working on other problems on my Aerostar, I found out the radiator was cracked, so I got a replacement spectra from PepBoys, took the old one out, tried to get the couplings off for the brass, but they were impossible to get off, set it to the street, put the new one in, and found out the brass screw in couplings for the transmission cooler wouldn't fit the transmission lines, the hole they screw into on the couplings were too small. Wanted to try the couplings again off the old radiator, but junkman had already gotten it. Why would Spectra make the wrong size couplings? I went to Autozone and their couplings had the same problem! Then I went to the dealership and they didn't have the proper couplings and said Ford didn't even make the radiator anymore! So I'm not sure what I should do, I'm gonna contact a radiator place here locally, but has anyone else had a problem like this? Does anyone know where I find find the couplings online? Thanks
Old Jul 12, 2010 | 10:48 PM
Navyguns's Avatar
Navyguns
I haven't had that issue. Got a junk yard in the vicinity? You might also check your hardware store for the proper couplings, they are standard tubing couplings.
Old Jul 13, 2010 | 03:02 AM
MFJ's Avatar
MFJ
Lightbulb
I would think about getting a bigger separate transmission cooler and not using the one built into the radiator at all. Reduces the chance of the strawberry milkshake (coolant in the transmission fluid), which is quite bad.
Ford liked to change things over the years, and being a last-year Aero, I think anything would go.
parr4
Jun 29, 2016 09:54 PM
kla94
Mar 19, 2016 08:20 PM
BYOBoat
Jul 22, 2015 11:07 PM
slowhand7609
Dec 12, 2013 07:03 PM
Mother_Love
1978 - 1996 Big Bronco
27
Jun 19, 2013 06:17 AM
