89 e350 leaf springs
I crawled underneath the truck and inspected the rear axle and leaf springs. No broken U bolts. I measured from the front eye bolt on the spring to the axle on both sides and the measurements were the same.
Only thing I noticed was that the thick steel straps around the springs were broken off on the right side rear (both sides) and the front straps were bent outward. On the left side one side of strap was broken off on in the rear and the in the front.
I know virtually nothing about leaf springs but it would seem to me that the straps are there to keep the springs straight, hence keep the rear end from drifting side to side. If they are broken seems to me the truck wouldn't sit straight on top of the axle.
Right? Wrong? Suggestions and comments appreciated.
