06 expedition ac freezing up
Hi all..
I have a 06 expedition limited and have been having a ac problem for some while now.. Around town both front and rear ac work and blow cold air just fine. While on the hwy 20-30 miles on road outside temp 90+,ac starts to fade, on high you can barely feel it coming out of the vents but it's still loud... Evaporator is freezing up..after a hour plus of hwy driving the rear will slowly fade away also..I can turn off the ac off and around 5 minutes turn it back on and the ac will work good for around 15 or so minutes before fading away again. Had the ac checked out,no leaks,not low on freon. Suggested the front expansion valve be changed..tried that and still same problem..temp monitored from the vent gets as low as 28-30 degree F before fading away?? Any suggestion greatly appreciated..
What you describe is caused by the evaporator getting too cold and freezing the condensation on it.
The evaporator pressure/temperature is controlled by the cycling switch. It's supposed to turn the compressor off at 29psi on the low side, which equates to about 33 degrees evaporator temp.
It's very likely the switch is cutting out at a lower temp or not at all, the shop should have checked this. They also replaced the "front expansion valve" on a vehicle that doesn't have one. The front uses a fixed orifice tube.
Replace the Cycling Switch (aka:Low Side Pressure Switch) and you should be fine. Just unscrew the old one and screw the new one on.
Also, think about finding another shop.
Oops, I was mistaken. The 07 does have the block on the front AC. I was thinking of the earlier system. My apologies.
That's correct, no cycling switch with the expansion valve.
With a non equalized TXV without a sensing bulb in the evaporator, the only thing I know of that "might" cause your problem is a slight refrigerant under charge. Likely about 2-3 ounces.
It's possible that the system has a sensor in the evaporator that signals the PCM to shut down the compressor if the evaporator starts to ice up. I don't have the service info for your truck, though.
Thanks isrx101.. I spoke shortly with a ford tech and he suggested I have the Evaporator discharge air sensor checked out.. I made sure it was connected and it appears to be in good condition upon prying it out of the box. I can have ford hook it up and scan/run a test to see if it functions right but I'll prolly just replace it.. Around $50 might be cheaper this way..your thoughts?? Thanks!!
Yes finally!!! It was the evaporator discharge air sensor as mentioned above. It cost $51 at the ford dealership anymore questions you can email me at ndogg3539@aol.com
Drenalin
57
06-23-2023 05:39 AM
AGrayson84
07-20-2017 05:54 AM
Wes032
08-07-2013 03:43 PM
2006, 99, ac, air, conditioner, discharge, evaporator, expadition, expedition, f150, ford, freeze, freezing, loction, orifices, rear
