Air intake suggestion, or not for the 6.0?
on
texans is correct on that one. With regard to performance both for more air flow as well as filtration qualities, you can't beat the stock intake. There are people with more HP then myself(and I'm at 508) that also still have their stock intake. I can promise you that at that price range to get higher then I'm at, the cost of an intake is nothing relatively speaking. Even the ability to clean it and reuse the filter may or may not be a valid reason to get one depending on the situation that the truck has to "live" in.
papadelogan
12-13-2006 08:37 PM
