Very strange taillight problem - light goes out when brake is depressed. Why?
#31
Quick update:
I switched out the taillight/brake bulb and front turn signal bulb on the left side (the problem side), and cleaned the ground connection for the left taillight. This is all I've had time for recently. Unfortunately it hasn't improved anything. I guess I'll clean the other taillight ground. I couldn't replace that bulb because it's stuck in there and I don't want broken glass embedded in my hand from pushing any harder.s
#33
#35
Update:
Checked for continuity between the chassis and both taillights, reverse lights and the front left turn signal.--Is it normal to find "continuity" on every wire of the taillight & turn signal harnesses? Because I did.--Inside the taillight socket I found continuity between the chassis and both contacts at the bottom of the socket (same on the front turn signal, if I recall correctly). Continuity between the chassis and both contacts on the left reverse light and only one (side contact I think) contact on the right reverse light.
Does any of that mean anything? Narrow it down or point in any direction. I'm confused about the continuity that was found on every wire in the harness for most of the lights.
It was mentioned earlier that there may be a "wiring fault between the parking lamp circuit and turn signal lamp." How do I check that?
#36
on
Update:
Left rear turn and brake socket continuity test.
1: Continuity between Chassis and side connection.
2: No continuity between chassis and the two bottom connections, with the bulbs removed.
3: No continuity between the two bottom connections.
Check the continuity with a multimeter set to ohms, and all power to the truck off. Disconnect the battery ground cable etc...
#37
#39
Yes, all four corners light up. The strange thing is that when the parking lights and hazards are on at the same time the rear hazards flash opposite each other, and the passenger side parking light (taillight) is on, while the driver's side is off.
Additionally, I just noticed that the left-hand turn signal works just fine...unless the parking lights are on. Once the parking lights are on it either stops working (stays dimly lit when it's supposed to be on), or is very very sluggish. But the indicator on the dash is very dimly lit at all times that the parking lights are on.
Glad I found another clue...wish I knew what it meant. lol
Check for continuity between the body of the truck to the ground pin in the socket. You can't see it, but the ground pin corrodes down inside the shell of the socket so there is no connection between the pin and the wire.
#40
Chassis Continuity Update:
Left taillight:
Additionally (since testing all of the bulbs & harnesses), the left turn signal is now a little slower than normal without the lights on. The signal now flashes (without parking lights on) in the driver's taillight and not the front driver's side light. With the parking lights on it flashes in the front driver's side light but not the taillight (it goes black).
I've also noticed that when the parking lights are on and the left turn signal doesn't work (just stays lit on the dash when turned on...sometimes works sluggishly) that if I press down harder on the turn signal lever that the turn signal indicator on the dash goes out.
What's going on?!
Left taillight:
Socket - Continuity on bottom two contacts, nothing on the side contact.
Harness - Continuity on both black wires, none on the yellow/black wire.
Left reverse light (does not work with parking lights off or on):Harness - Continuity on both black wires, none on the yellow/black wire.
Socket - No continuity.
Harness - Continuity at both wires.
Left front turn signal:Harness - Continuity at both wires.
Socket - Continuity at both bottom contacts, none on the side contact.
Harness - Continuity at all three wires.
Right taillight:Harness - Continuity at all three wires.
Harness - Continuity on all wires (two black & one green).
Right reverse light (does not work with parking lights off or on):Harness - Continuity on all wires (two black & one green).
Socket - Continuity at both contacts (once thoroughly cleaned).
Right front turn signal:Harness - Continuity at both wires.
Socket - Continuity on the side and one of the bottom contacts.
Harness - Continuity on the red & black wires, but not the blue one.
Side-marker lights (all work fine):Harness - Continuity on the red & black wires, but not the blue one.
Sockets - Continuity at all contacts.
None of this makes any sense to me. I was hoping that something would stand out as a clear oddball, but it's all random (to my novice eyes). I was very thorough and took a great deal of time double and triple checking these results. I've cleaned both taillight grounds. I haven't had an opportunity to clean the battery/engine or engine chassis grounds.Additionally (since testing all of the bulbs & harnesses), the left turn signal is now a little slower than normal without the lights on. The signal now flashes (without parking lights on) in the driver's taillight and not the front driver's side light. With the parking lights on it flashes in the front driver's side light but not the taillight (it goes black).
What's going on?!
#45
