PCM Bad? 94 Bronk 5.0 MAF E4OD
Well i got a 94 bronk as my mud truck. Ran awesome for a few months, mostly jumping the **** outta it. Well I was doing a huge jump and then I landed and it stalled out. No fuel pump. So I checked for power at the intertia switch none, ran a power wire too the swith to see if it would work. Yess it runs, but still doesnt start. Started to ck fuses and relays. Good, checked for power and ground to the ECC relay and Fuel pump relay. I have power but was losing it goin to the ecu, found corroded wire at ecu, got power at ecu now, still no start, fuel pump still not running, LB/O is the ecu ground sig, for the fuel pump relay, wire good to the ecu, if I add ground then the pump runs, still no start, have to ck for injector pulse and spark, but thats hard alone. Anyone think bad PCM also?
Try shorting pin #2 to to pin #6 of the EEC Self-test plug and turn on the key and see if the pumps run. I know you said you grounded pin #6 and they ran but do the above test and see if they run that way.
If they do not run that way then you have a bad Computer ground over near the battery.
Pin #2 SIG GND is ground through the computer pin #46. Pin #6 is coming from the coil of the fuel pump relay. The other side of the fuel pump coil comes from the EEC power relay.
Computer pins 40 & 60 go to the body ground or the NEG Post of the battery.
Pin #2 ground through the Computer (SIG GND J1-46):
Then you have lost the ground to the computer or you have a bad computer plug or computer.
There should be a wire going from the NEG post of the battery to the RH front of engine compartment, front of fender apron. Photo below.
There should be a wire (black with a white stripe) leaving this ground point and going to pins 40 and 60 of the computer plug. This wire also has a splice before it gets to the computer and goes to the MAF sensor.
Unplug the computer and jump pin #60 or #40 to pin #46 on the computer plug and see if pin #2 is still hot with your test light. Do not use a meter to test pin #2 as a meter may lie to you at this point.
If it is still hot you have an ope wire someplace and the computer is OK at this point.
Note after the "/" in the wire color is the stripe on the wire color.
GY/R would be a Gray wire with a Red stripe.
