03 Expy 5.4 Broken #4 Plug
I have an 03 5.4 with the 2 Valve heads (w/rdesigned plug threads) and 78K miles. I started to feel a miss when it was cold and it finally threw a single #4 misfire code. I replaced the COP and noticed that the plug well was very rusty (a known water issue I learned on FTE), so I ordered a set of boots, springs and plugs and decided to take on the dreaded plug change.
I left #4 for last as I knew it would be the toughest. All the other plugs went very well when I followed all the advice from those on this site. Once I made it to #4, I blew out the well with air and there was a bunch of rusty dust. I added more penatrating oil and gave it an extra 30 minutes, and with virtually no effort at all came out with half a spark plug. The plug was basically rusted in half with the porcelin being the only integral part of the plug. Now I have a broken plug flush with the base of the well with the porcelin still in the head. There is nothing to grab and I'm not sure about busting the porcelin out for fear of dropping pieces into the cylinder. I even started the engine to see if the center porcelin portion would be blown out of the plug base, but it held tough.
I think it may be time to punt to the dealership, as I have learned over the years when to stop digging. The moral of the story is to take a good look at #4 occasionaly and once this is fixed, I'll replace that plug more frequently if I see any rust. I wont comment on my feelings regarding plug or head design.....
Steve
And on top of that, a week to get it back due to the holiday........
Go ask an independent shop that same question and I'm willing to bet you can drop at least the "2" off the front of that number.
LISLE 65600 5.4L Broken Plug Remover
Good luck!
John
