Hey guys....i've noticed that when i make a right turn and apply throttle i get a bit of a clunk in the driveline....oddly it doesn't do it turning left......anyone have any ideas???
yep....its not a ball joint....they're all new....(by the way...if any parts guys tell ya you have to change the whole lower arm.....they're on crack).....the part is listed under a 05....but not an 07.......same lower ball joint....
Ok, the ball joints and sway bar end links are new.
Now is the cluck the same as the sound you had before you changed these? If it's different, then I'd say it's not a problem with one of the new ball joints or end links. If it's the same sort of noise, then check those new parts out. You could have something that came loose or was damaged (there really are lots of forces applied to front suspension components) or you installed defective parts.
Rule that stuff out and move to other possible sources.
I had that noise. My trans crapped out shortly afterwards. i found chunks of metal in my trans filter. it sounded like a back brake dragging at first. It quit...now.
