Sponsored by: Real Truck
Help Removing Inside Door Panel
Old Jul 1, 2010 | 09:43 AM
florida_1959's Avatar
florida_1959
Was wondering if anyone could guide me in getting the inside door panel off my LR door on a 2006 F250CC. I hate to just start prying and mess up all the little plastic fasterner plugs or crack the spots the are set in the panel. And being as I am new to ford, I dont even know where the attaching screws are on the upper portion, I assume near the pull handle area. I have the simulated wood inserts and would hate to mess them up searching for the screws. Any help is greatly appreciated.
Old Jul 1, 2010 | 10:20 AM
rickf92592's Avatar
rickf92592
Time to pop $15.00 on a Haynes manual?
They have a step by step w/ pictures in there.
Old Jul 1, 2010 | 11:18 AM
Rugby3's Avatar
Rugby3
There is one bolt behind the reflector, remove that then "push/lift" the panel up toward the window. DO NOT pull it out away from the door. The panel has hooks that hold it onto the door.
Old Jul 1, 2010 | 11:22 AM
cartmanea's Avatar
cartmanea
Pop off the window control cover and the reflector, there is a screw under each one. After the screws are removed and the wiring is disconnected from the window control, the panel just lifts up.
edit: I guess Rugby3 beat me to it. I think there is a second screw under the window control, but I don't have a crew cab
Old Jul 1, 2010 | 01:28 PM
hotnanas's Avatar
hotnanas
PICS -> LINKY-Ford F250 Excursion door panel removal-CLICK ME!!!
JR Truck
2004 - 2008 F150
Nov 27, 2013 06:19 PM
yogmuney
Dec 16, 2011 07:56 PM
golfnut324
Dec 26, 2010 10:15 AM
OnTheTrail
Jun 11, 2007 09:08 PM
Dinglo
Feb 27, 2002 09:17 AM
