Gas Shooting Out of Carb
Ok, guys here is the situation...I have '78 F100 Custom, with a 351W (I put it in) C6 transmission....I removed the stock intake and Holley Carb and swapped them out with a New intake (Edelbrock 2181) and a New Carb (Edelbrock 1406). I have been waiting on some parts to come in, they finally came in yesterday, so I installed them, and attempted to start the truck just a minute ago. Truck fired, ran rough, figured I needed to adjust the idle mixtures, etc...got out to adjust the screws, truck began to "chug" like it was choking out, as I reached under the hood to give it some gas via the throttle linkage, it died, and as it did, it SHOT GAS OUT OF THE TOP of the carb, from both rear jets (ports)...cleaned it up, tried to start it again, same thing...so what would cause it do this? I really need to get it back on the road, because my in-laws are finally moving out of my house after a year, and I would love to help move their stuff in my truck...suggestions? Recommendations? FIXES? The shots were about 8" in height...almost to the rear of the hood in the raised position...then the carb appeared to "steam"....I have a 3/8 hose as the fuel line as per the instructions provided...there isn't a fuel filter, but I could install one if need be...any other information can be provided upon request.
Thanks
Thanks
Anyway to "unstick" it...or does it sound like it needs to be rebuilt? I purchased from a small shop close to me...it was pulled and running fine per the mechanic...so it is used, but looks to be in like new condition...the shop said a guy was downgrading his son's bronco to a 2BBL to keep him in control...
Don't be suprised if it doesn't work, 50/50 chance. If it doesn't work you'll need to pull the air horn (top) off the carb. I'm not real familiar with the Edelbrock carb. but a rebuild is probably in your near future.
I called around this afternoon, and found a rebuild kit...would it be worthwhile to spend $40 and rebuild it...I could do it tomorrow afternoon...returning it is a no go...I purchased it used, from a local mechanic...tapping it sounds fine, but does it sound as if it is in need of a rebuild?
78 f150 400
03-10-2017 12:06 PM
bigfoot22
06-11-2016 09:05 PM
FordPower2038
12-08-2014 07:15 PM
blue04.5
33
04-03-2014 10:16 PM
