69 f100
69 f100
hey guys when i bought my 69 f100 it had a holley 750 carb on it and thier was no kickdown lever attatched to the carb or the trans. the throttle was rigged up with coat hangers. would something like the lokar kickdown cable and throttle cable kit work for this setup. im kinda stuck here and not sure what to use to make it work and look right. if anyone has used the lokar setup could you please post a pic so i can see how it was hooked up. thanks alot-Ryan
Here is a really helpful link that shows you how to make a throttle linkage for your truck. As for the kickdown,,,,,good luck. What a pain, I searched everywhere for one and finally found one but I have been told that the Lokar kickdown cable will work just fine.
FORDMUSCLE webmagazine: Make Your Own Custom Throttle Linkage
ok i can make the rod work for the throttle, but im going to have to figure out something for the kickdown. the lokar cable wont work because the bracket gets in the way. does anyone know what years of f100 kickdown rod i can use maybe i can find one. i heard all the way up to 79 will work can anyone confirm that for me...
Whichever one it is...may not work with the carb you have now....prolly why it's missing.
The kickdown rods are hollow steel tubes pre-bent at the factory for whatever the application is. Some of these can be-rebent...IF they are the correct length.
What size is the engine? 302? 360/390? I need to know this to give you the factory original applications for the kickdown rod, but...
Fits 1968 F100/350 & 1969 F100/350 360 before serial number D96,001.
C9TZ7A187B .. Transmission Kickdown Rod / 34" overall length / 1/2" diameter rod / Obsolete
Fits: 1969 F100/350 360 & 390 from serial number D96,001.
No Ford Dealer or obsolete parts vendor has either one.
C8TZ7A187A .. Transmission Kickdown Rod / Obsolete
telmoff
06-12-2022 09:19 AM
F-250 restorer
01-12-2013 01:47 PM
CountryBumkin
10-25-2012 04:30 AM
taylorjgreen
02-23-2012 07:00 PM
1972fordf-100
07-07-2010 04:21 PM
