SEIZED UP 2006 F150
  #31
Old 08-14-2010, 01:52 PM
2006F150DIED's Avatar
2006F150DIED
2006F150DIED is offline
Finally got my truck back after $8,400.00. Holy ****. Not only was the engine shot, but so was the torque converter too. The funny part was that I had them install a rebuilt Ford motor and after they put it in, the new rebuilt was bad and had to be changed out. I have had it back for two days and it seems to be running fine. I am mailing the paperwork back to the Better Business Bureau on monday and I will be curious to see if they have any luck. I had no luck dealing with the local dealership or the 800 customer service number. Someone had suggested getting ahold of an area rep for Ford, but nobody wanted to give out that info.
  #32
Old 08-14-2010, 09:52 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
Wow that a lot of cash for a engine especially when a independent shop does the work. What was the deal with the torque converter? Did you have any symptoms before the engine work? Also what was wrong with the first reman? I have installed many Ford remans and have not had a single problem with them.
  #33
Old 07-02-2012, 10:32 AM
tyree's Avatar
tyree
tyree is offline
My wife and daughter were en-route to Canton Ohio where my daughter is getting married, when the engine in my 2005 F 150 5.4 Triton began to run rough and the engine light came on. They had just left the motel they had stopped for the night, They drove to a Ford Dealership where-by they were told that there was a problem with the number 7-8 injector They were to full up to work on it and suggested another dealership that would be able to fix it. But before they got the truck out of the bay the engine seized! The truck had to be towed to the Ford Dealership in Pilot Mountain North Carolina. Right now they have just arrived. Ford should provide them with a ?rental car so they can travel on to Canton and hopefully they do. I am flying up later on this week and if all works out, My Wife and I will drive back to Pilot Mtn. in the rental pick up my truck and then we will drive on home to St. Cloud, Fl. where we live. I will keep yall updated, Thanks for the Info It will help me out on knowing the Skinny on the engine and the Fix.
  #34
Old 07-02-2012, 11:14 AM
berry1234's Avatar
berry1234
berry1234 is offline
Yikes, $8400 for an 06' truck?
I personally would have gone wrecked engine-$500-$1000 plus $500 +/- labor.
  #35
Old 07-02-2012, 08:06 PM
FORD COASTIE's Avatar
FORD COASTIE
FORD COASTIE is offline
Supporter of Patriotism
Received 2,358 Likes on 1,706 Posts
Sorry to hear about your bad luck. How many miles did your engine have?
  #36
Old 07-02-2012, 08:24 PM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,425 Likes on 2,340 Posts
If you lift that body up 6/7", pull the front tires and inner fenders out you can do that yourself. Have a machine shop fit a new piston and rod along with bearings and away you are for about $700.00 + the body lift kit. There are suprises with each job, but I think you got hosed. You got a warranty with this motor so you are good to go. I would have done it different, getting it towed home and done it myself, but I'm lucky that way, just work my arss off. LOL
  #37
Old 07-04-2012, 02:24 AM
tyree's Avatar
tyree
tyree is offline
Pilot Mountain Ford, That's Andy Griffiths old stomping grounds FYI
put in a new injector, changed the oil and put them back on the road,
It ran fine for about two hours and then it started running rough, engine lite came on etc. they managed to limp into Canton, and there it sits.
Of course I am a thousand miles away, I told my wife to contact the nearest Ford Dealer and have them come tow it. The engine has about 104,000 on it well within the limits of the recall that's on the engine.
From what my future son in law reports the engine is shot. So I will demand that Ford replace it. I will keep yall informed.
  #38
Old 03-31-2015, 03:32 PM
wildbillhatchbac's Avatar
wildbillhatchbac
wildbillhatchbac is offline
4.6 L locked up
My 2005 4.6L began to misfire Saturday night. Quickly went to a knock after I idled down the closest off ramp. Cylinder #8 hydrolocked. There's internal damage judging by the looks of the plug. My extended warranty expired 2 days and 7400 miles before this happened.
It's at the dealer now and I had to talk to he general manager just to get someone to work with me to start a case with ford. I called ford myself and they explained it's on only 5.4L engines and here is no satisfaction program that refers to my 4.6
I've been a mechanic for 16 years. I know this is the same problem. And just out of my extended warranty.
PLEASE IF ANYONE HAS INFO THAT WILL HELP ME MAKE FORD RESPONSIBLE POST OR EMAIL ME
bill.cranford@gmail.com
Thanks so much
  #39
Old 03-31-2015, 03:52 PM
wildbillhatchbac
Thanks so much
Build date is 01/05
skyking897
1999 to 2016 Super Duty
04-20-2017 11:40 AM
grogreen
Modular V8 (4.6L, 5.4L)
04-07-2017 10:23 PM
grogreen
12-20-2016 05:49 AM
ez2bbad64
2004 - 2008 F150
03-03-2016 07:11 PM
ford f150 truck
1997 - 2003 F150
06-14-2014 08:11 AM
Quick Reply: SEIZED UP 2006 F150
