Carpet replacement 06 F250
I decided to replace the carpet in my Crew cab. Big mistake. I started by ordering the vinyl mat since I figured it would be easier to clean. It came in and was almost brown in color, I guess beige has many shades. Didnt fit worth a crap, not contoured, very lumpy nothing fit right. Sent it back and Ordered an actual carpet. This one looked much better and I could see the moldings/contours in it. I figure it would fit a lot better. Wrong. Nothing lines up, nothing fits right. It wont lay down on the floor and is bowed up everywhere. Been in the truck a week with the front seats bolted in and I was hoping the heat would settle it in. Nope. I dont know what to do. Any advice?
J
J
The first one came from rockauto.com and luckily they took it back. The second came from stockinteriors.com. Both were ACC brand. I called stock interiors and was informed that ACC makes 80% of the replacement carpets and that finding someone else that made customs would be difficult. I'm actually going to pressure clean my original tomorrow and see how clean I can get it.
I was in the Upholstery Business for 20 years before moving on to my current profession. When they first started making molded replacement carpets they didn't fit well. Over the years they have gotten better. One trick we used was to steam the carpet into place and use fast-tack trim adhesive to hold in in place. Remove the seats, and console if necessary, lay the carpet in the truck and start at the front and steam it until it relaxes. Applying steam will also allow it to stretch a bit.
Kind of. You can see some definition of the center floor hump but the floor pan not so much. I have installed these kits in many trucks mostly regular cabs, the crew cab is a challenge for sure. Use a heat gun, harbor freight like $12, and warm the vinyl and shape it. Lay the mat outside in direct summer sunlight for hours before install. This time of year, I would not go for it. My garage even with the wood stove cranked the mat will not work with you. The seat bolt holes and such use a hollow punch. You will have to trim for the door sill plate area and firewall area.
Thumper19
12-07-2011 02:02 AM
dohc_chump
06-07-2011 04:47 PM
bulletsneverlie
06-09-2009 09:39 AM
Ken2600
02-13-2003 09:18 PM
