1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
installing clearance light
Old 06-27-2010, 05:59 AM
redford's Avatar
redford
redford is online now
Received 1,549 Likes on 904 Posts
Originally Posted by spinella
i used red loctite on the nuts. i'm hoping i'll never remove the lights.
You used red? Oh crud.
Loctite® Threadlocker Red 271™ is designed for the permanent locking and sealing of threaded fasteners. The product cures when confined in the absence of air between close fitting metal surfaces. It protects threads from rust and corrosion and prevents loosening from shock and vibration. It is only removable once cured by heating up parts to 500°F (260°C).
Old 06-27-2010, 06:06 AM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
I used no silicone or loctite or sealant of any kind...
doing just fine. no leaks, no rattles.
Old 06-27-2010, 06:34 AM
spinella's Avatar
spinella
spinella is offline
i've been using red for years. its not as permenent s they would like you to beleive. if i did have a hard time with it then i would just break the light topside and then remove the rest from the bottom.
Old 06-27-2010, 09:55 AM
skylinekw's Avatar
skylinekw
skylinekw is offline
What kind of lights did you put? factory or after market
Old 06-27-2010, 10:33 AM
4starcstms's Avatar
4starcstms
4starcstms is offline
I added OE lights to my 04 back after new years, it was far easier than I figured it'd be..I followed the same link and it was a big help..
No Silicone for me either, and leak free, six months now
Old 06-27-2010, 01:50 PM
spinella's Avatar
spinella
spinella is offline
factory lights and harness.
BigZ97
12-17-2014 07:37 AM
klashorst
12-27-2011 07:01 PM
Rongold
13
12-08-2007 09:21 PM
closetredneck
11-10-2005 06:32 AM
Quick Reply: installing clearance light
