need advice..54 ford 4X4
  #61
Old 07-06-2010, 09:10 AM
kenjh's Avatar
kenjh
kenjh is offline
kenjh has a good reputation on FTE.kenjh has a good reputation on FTE.
i have a buddy with 3 power wagons..never thought of checking with him..an' he is on the island ...and last night I made the last payment on the truck so it's all mine ,,and the wife know's and isn't mad at me ..yet...I think...well back to work so I can play with this some more..
  #62
Old 07-06-2010, 12:42 PM
1952's Avatar
1952
1952 is offline
1952 is starting off with a positive reputation.
Originally Posted by truckdog62563 View Post
That's where having the parts manual would be a big help. And like we discussed in regard to the other person interested in your axle, we don't know whether MH might have used the lighter duty A-150 on the front of an F-350 in combo with the heavier B-150 rear. Modern trucks have the D-60 rear in combo with a D-44 front, so maybe the same was done back then. Stu
If I remember correctly, Chuck once told me he adapted a turning knuckle out of a Caddy Eldo for use in a 30s or 40s woody a fellow had him tinker on.
  #63
Old 07-06-2010, 01:00 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
truckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant future
Good lnfo. And l've actually responded on my new Droid! Stu
  #64
Old 07-09-2010, 09:36 AM
kenjh's Avatar
kenjh
kenjh is offline
the good news.. it is in better shape then I thought...he did take care of this ol' girl good and solid where it should be everything still has grease and oil..bad news ,, new brake cylinders and master is in order.
  #65
Old 07-09-2010, 11:26 PM
1952's Avatar
1952
1952 is offline
I started taking that front axle apart. It will need new tie rod ends! Those puppies are stuck, stuck, stuck!!! However, once I got the seal retainer/tie rod mount off, the hub/drum assembly rotated around the trunnions very smoothly. Nothing like the smell of 90 wt. grease!
  #66
Old 08-26-2010, 12:23 AM
kenjh's Avatar
kenjh
kenjh is offline
the breaks work .. but the gas tank leaks.. new one on the wayit sounds great it runs great .and now I have 2 spare motors and a trans ..the tire are holding air and look good..did ford ever put a winch on this truck or was that a owner installed part??
  #67
Old 08-26-2010, 06:19 AM
truckdog62563
Ken - I don't think a winch would have been a Ford option. Probably it would have been a M-H option or an aftermarket add on. We've seen them commonly on the big models, but not on the 3/4 ton or one tons. The trucks were, however, able to accept PTOs mounted on the transmissions. M-H also had their own PTO to mount on the truck's transfer case. Stu
  #68
Old 08-26-2010, 08:44 PM
vintage56's Avatar
vintage56
vintage56 is online now
vintage56 is gaining momentum as a positive member of FTE.
that is a beautiful beast!
I'm in love.
congrats on a monumental find!
JML
  #69
Old 08-26-2010, 10:24 PM
kenjh's Avatar
kenjh
kenjh is offline
how big a cab over are you looking for??I saw one last week .a dump truck in a feild ...looked good from the road .. I will try an get a picture for you.
  #70
Old 08-27-2010, 12:53 PM
vintage56's Avatar
vintage56
I'd much prefer a Big Job (C-750, -800, or -900) but a C is a C. I'd be stoked with any 56 (or 53-55) coe. BUT, I don't plan on using anything other than the sheet metal. So the Big Job wish is little more than emblems, badges, maybe a hood scoop.
JML
MarkA100
Modular V8 (4.6L, 5.4L)
16
04-06-2017 11:31 AM
jonlesher
New Member Introductions
05-10-2016 06:13 AM
ssandirene
2015+ F150
03-16-2016 02:02 AM
Apocalypse
11-03-2014 09:02 AM
justforkicks
1997 - 2003 F150
05-07-2014 02:48 AM
Quick Reply: need advice..54 ford 4X4
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
