need advice..54 ford 4X4
Old 06-26-2010, 08:58 AM
55 f350's Avatar
55 f350
55 f350 is offline
55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold
well if stu the mh brain say's that sucker is that rare well ................ just remember ......... LET THE GRASS GET REAL TALL .. SHE'LL NEVER KNOW IT WASN'T THERE BEFORE !!!!!!!!!!!!!!!!
Old 06-26-2010, 09:35 AM
petey shoes
petey shoes is offline
petey shoes is gaining momentum as a positive member of FTE.
if front driveshaft is not connected, more than likely there is a broken axle. possible transfer case damage, but not likely. jack up nose, check it out. either way--- still worth it
Old 06-26-2010, 09:54 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
truckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant future
I agree that the front drive shaft is disconnected for a reason. Not a happy reason. I have that on one of my trucks too because one of the front half shafts is bad. Fortunately I was able to come up with a spare front axle. Stu
Old 06-26-2010, 10:01 PM
kenjh's Avatar
kenjh
kenjh is offline
kenjh has a good reputation on FTE.kenjh has a good reputation on FTE.
ok what the heck is a timkin 150?? the bad news is yes the front axel or hub is broke ? he dosn't know witch ,the breaks don't ..the front turn signels are missing ...moved 3 wasp nests out of the cab it was last painted in 1990 with house paint...it needs running boards .tried to move it and the right front wont..but I sat and listned to peter the owner and after we talked and he was sure I wasn't gonna wreck it .. he lowered the price to $1000 so now it's half paid for ...it has badges on both fenders marmon harrington all wheel drive and the insructions or on the dash plate for useing it ,the tyres were new in 90 do you think I can get away with them for a year or two ??..crap now I have ...5 trucks a ranchero 2 65 t birds...why is my blood still red an' not ford blue??an' where can I get decent fenders for MY long box ford .??dearborn doesn't seem to have any nor does perogie...
Old 06-26-2010, 10:11 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Originally Posted by kenjh View Post
guy's your supposed to help me not add one more !!I shudda known better..well...
Hey, what are friends for!!!!!
Congrats on the new ride!
Old 06-26-2010, 10:20 PM
kenjh's Avatar
kenjh
kenjh is offline
do you think it would be easier to stick a dana 60 up front till I can fix the old front end? it looks realy wierd under there with that goofey drag link and that big ball end swivel now where ccan I find a clymer manuel for this damm thing???gotta battery chargeing ..tomorrow fresh oil and gas an' wake her up...I hope
Old 06-27-2010, 04:41 AM
truckdog62563
Swapping in some different front axle makes sense until you can sort out what's wrong with the original. Finding one that will connect to the original drag link so it'll steer, I'd think, is the issue. Just don't let the original get separated from the truck if you end up having to resell it.
The front axle and rear axles should be the same as far as the differential is concerned. It's the half shafts and CV joints that are unique on the front. A Ford service manual would give repair instuctions for the differential. Finding an original MH service manual for that model will take a miracle. One of our members, though, was able to get an online copy of his service manual right from MH. I've got his contact info and a link to the manual that I'll look up, then come back and edit when I find it. You might want to contact MH to see if they have an on-line version of yours. Edit - Here's the thread where Rab discussed it, but I can't get the PDF link to work. Stu
https://www.ford-trucks.com/forums/8...ce-manual.html
Another option is to swap in an axle from a F-250 MH. Our member 1952henry has a spare that he rescued from a yard. I know he's had another member interested in it, so don't know for sure that he still has it. I'll email him and ask him to check in here. He's in Oregon so would be reasonably close to BC for shipping. Below is a pic of his spare axle.
This is a Timken A150 as used in the 3/4 ton F-250MHs. It has a longer pinion housing than the B150 that was used in the F-350s. I'll go to a different computer and see if I can find the B150 picture and edit to include it. Edit - I added a second pic of an A-150 to show the longer pinion housing, and then the red/blue B-150. Stu
Old 06-27-2010, 08:19 AM
kenjh's Avatar
kenjh
kenjh is offline
WOW !!!I have never seen this kind of truck before.. never thought I would find parts ,,,I have been wondering what I got myself into,... again..the parts guys have gone to this site to get info!!! ...I was starting to think this was gonna be more then I handle ...with your help this old truck will not be crushed and become a toyota or hun-die ....you have no idea how much you are helping on so many levels...she may never be a show truck and will drive me nut's but I guess that why I love Ford's thank's guy's....
Old 06-28-2010, 07:16 AM
petey shoes
i bought 3 trucks just to have spare parts. now working on buying 4th. problem here is, i just can't seem to break stuff. (not complaining, really). i got it if i need it! i would offer up some parts, but, my stuff is much heavier than you need. good luck---get some pics!!
Old 06-28-2010, 07:37 AM
truckdog62563
Having spares is a good thing. There were more of the big trucks made which makes spares somewhat more available on them than on the smaller models. Not a lot more available, but somewhat. Problem we have with the in-between sized F-2/3/250/350 models is prior owners who used them like they were big trucks when there weren't really that much stronger than the half tons.
I emailed Owen (1952henry) about his spare axle, and also emailed him to see if he had info to help another M-H guy that Bob Jones connected with me. I've not heard from him so suspect he might be on vacation or otherwise away. Stu
Old 06-28-2010, 09:34 AM
kenjh's Avatar
kenjh
kenjh is offline
thanks for keeping me in gear..going to try and get her lit after work today ,I found a couple of manuels at the car swap on sunday so now i have an idea what to look for on breaking her down,,so far it all looks good under there no cracks no drool of oil or chunks of solid grease thing move and undo ..and found the M-H website..so things are progressing. getting rid of my 87 crew cab diesel so i have a place for this old girl..
Old 06-29-2010, 10:30 AM
truckdog62563
I just heard back from Owen and learned that he still has the axle, but hasn't resolved whether the first interested person wants it. So stay tuned. If you find that you have to replace the axle, you might also contact Chuck Mantiglia at Chuck's Trucks in CT to see if he has a line on any spares. Stu
http://www.chuckstrucksllc.com/startframe.htm
  #28
Old 06-29-2010, 09:06 PM
kenjh's Avatar
kenjh
kenjh is offline
does anyone know a Don Chew in calarado? the marman pepole said he is the one to go to for info and parts...heck this is getting fun again!!!
  #29
Old 06-29-2010, 09:43 PM
truckdog62563
Yes, I've spoken with him on the phone and enchanged letters once. I'm sure he's been into M-Hs longer than Chuck simply because of their age difference. He lives in Brighton, CO. When I was in contact with him he wasn't a computer user, so you had to communicate by phone or mail.
Chuck told me that he and Don got together a number of years ago to share info on production numbers and other details of the old M-H Ford trucks since most of the company's old records were lost in a factory fire many years ago. If you are a member of the American Truck Historical Society (ATHS), Don is a board member-at-large. As you'd expect, he has a very extensive M-H collection. Here's a web site with pics of his collection. If you want to contact him, I can post his address. Stu
Colorado Road Trip Truck Pictures - Day 9
  #30
Old 06-30-2010, 03:59 AM
55 f350's Avatar
55 f350
55 f350 is offline
don't forget ken that the fun is tempered with aggravation upon occasion !!!!!!! dain stu nice pics . i like the 42 and the 56 myself ........... oh and that old mack integral sleeper cab needs to find it's way to my drive . i'm sure i could find a crap late model ford f350 or 450 to plant that on !!!!!!!!!!!!! know where theres a 93 4 door f350 with a diesel now for 900 as the tranny is broken { manual } ........ hmmmmmmmmm .............. so have you put some pics up yet ken ??????
Quick Reply: need advice..54 ford 4X4
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
