Truck won't start
https://www.ford-trucks.com/forums/3...ch-folder.html
here is a link to the tech folder. It has tons of info for troubleshooting.
If it starts after being plugged in, check the FICM voltage. You can follow the following specification.
https://www.ford-trucks.com/forums/8...procedure.html
I'm with Bud on this, at least without knowing more. Get the truck code scanned. It will tell you if you're having glow plug issues. The block heater only warms the coolant and does nothing else as far as electrically aiding the truck. Do you get a long crank time and lots of smoke when it's not plugged in?
