How do I adjust the parking brake?
Thanks!
could be worse, on my GM Dually, one side is really easy, you can directly see the starwheel and it's straightforward to adjust, the other side you need to use a flashlight and mirror as well as a custom-bend tool because the slot is recessed a couple of inches and access to it is limited by the frame and spring pack. For extra fun, forget that with the mirror you you have to spin the starwheel the opposite way and wedge it...
Well, so much for that. As it runs out, my axle is a lot like Dave describes above. Driver's side is down low and relatively easy to get to. That said, I shined a light in there, and once I saw where the adjuster was, I could see it was back a way in the hole, and I think I was getting the tool in there, but can't tell if I was doing any good.
The passenger side is a whole different story. The plug is at the top, and thanks to the suspension, nearly impossible to get to.
I guess it'll have to wait till I need brake work, and I'll have whoever does that adjust them while they're in there. If I understand correctly, getting at them from the outside requires not only the wheels to be removed, but to get the rotors off and get to the internals, the axle shafts have to come out. Not something I'm going to attempt here.
Thanks, everybody.
Thanks, everybody.
1) Pull rubber plug out and use flashlight, you can easily see what you are doing then.
2) Leave wheels on, you can jack up one side at a time, CHOCK OTHER WHEELS and put truck in neutral so you can spin tire easily.
3) If you are lucky, your parking brake will work, if not you will be like others and still not have a parking brake worth two cents.
End of my rope! Dang parking brakes!
So just moved to MA and had truck inspected, 2002 F250 supercab 4x4, 300,000 + miles, yes 7.3 (love it). Fails inspection for ball joints and parking brakes. I have replaced all components ....I mean all of them, rotors, pads, cables, pins, springs, spreader lever thingy, dust shield...everything. I've taken that rear end apart so many times I can do it in my sleep. I've adjusted, bedded adjusted and sacrificed chickens to these dang brakes and they still won't hold. Inspection guys says they should hold up to 1250 rpm! They won't even hold just at idle. I even took an air chisel with the punch and put 10000 dimples on the inside of the rotor to try and give it some more grab...nothing. Help!
#28
#29
Look on youtube.
You can probably do it with the wheels still on. You also do not need any special tool. A flat screw driver should be able to move the cogs.Jack up both sides since you need to adjust both sides anyways. A flash light will help since it's on the inside of the wheel and kind of dark.
#30
E brake adjust
They say to remove the rotor and stick a 0.30 feeler gage between the rotor and e brake shoe. Also jack up both sides of the rear put on stands trans in neutral . Chock ft tires adjustment doesn't require disassembly. The adjuster slot is on the backing plate engage the park brake adjust both equally. If you adjust 4 clicks on drs side give the pass side the same. Release the park brake and reapply see where the petal is engaged figure about mid way to floor and it should hold
