360 to 460 swap
Old 07-09-2010, 11:10 PM
instig8r63
instig8r63 is offline
instig8r63 is gaining momentum as a positive member of FTE.instig8r63 is gaining momentum as a positive member of FTE.
Originally Posted by dlocklear11 View Post
hey does anyone know if the same ignition in the 68 f100 will work for the 460 i mean its a 70's model 460 but would i need to do any other wiring to get it going
3 wire plug from the firewall hooks up the same on a 460 except (on mine) the oil sending unit is on the block behind the intake.
Old 07-11-2010, 10:34 PM
dlocklear11
dlocklear11 is offline
dlocklear11 is starting off with a positive reputation.
how about the plugs from an 84 f-350, hillbillyk has one for sale and would like to drop in mine if possible
Old 07-28-2017, 07:40 PM
biggray75
biggray75 is offline
biggray75 is starting off with a positive reputation.
Originally Posted by 460-67-FORD View Post
figured the swap out i used 390 car motor mounts out of a 67 ford galaxy. tight but worked
so would the galaxy mounts work for a 75 ford f250 4x4 highboy?
Old 07-29-2017, 01:35 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.
Welcome to FTE.
This is a really old thread. You might not get an answer. This is the 67/72 board. You might go to the 73/79 board and post your own thread there. I'm sure they will help you.
Old 07-29-2017, 02:01 PM
RichS2659
RichS2659 is offline
RichS2659 is gaining momentum as a positive member of FTE.RichS2659 is gaining momentum as a positive member of FTE.
Use engine supports from L&L or Autofab if you can't fabricate. You can't use 2wd 460 supports on a 4wd truck.
Old ford fire
01-02-2017 04:52 PM
tbehrens1
19
12-15-2016 09:03 PM
mudder460
17
09-23-2016 11:13 PM
choptop49ford
05-05-2016 08:42 PM
Hunter Nelson
03-30-2016 01:57 PM
Quick Reply: 360 to 460 swap
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
