Fan Clutch Wiring
can anyone else help with this?
just replaced the water pump and i am hoping to avoid replacing the plow kit fan clutch as its $400 from the dealer. the wiring was ripped from the plug, so just looking for any help with rewiring. pictures would be ideal. the colors on the wiring on the truck side is differant the the wiring on the clutch side. thanks in advance.
I can't speak for KR, but mine works great without that accursed fan stator. No heat issues at all and it's so much easier to get to the fan and accessory drives if need be. The downside is that you have to redo your fan harness to keep the wiring out of the fan.
Maistro
You think if remove the stator help cool down at the hill,because my 06,6.0 when pull the toy holler on grade hills at105 degree the coolant temp go up almost to red, also when turnoff the a/c help a little.
Photo links not working
These are 10.1 mega pixel photo's. They are about 4GB each. But they are the best I could get of the wire colors of both connectors. Hopefully they will help.
http://www.chamberlain.homedns.org/m...00626_0224.JPG
http://www.chamberlain.homedns.org/m...00626_0225.JPG
http://www.chamberlain.homedns.org/m...00626_0226.JPG
http://www.chamberlain.homedns.org/m...00626_0227.JPG
I could really use those photos if you can send s im to me! Thank you the links just don't work anymore.
The following users liked this post:
Justin Jones
18
07-24-2017 05:20 PM
52flatheadf1
49
02-16-2016 07:31 PM
