GCWR
06-19-2010, 04:19 PM
on
GCWR
need help figuring my tucks GCWR. i have a 1987 f250 4x4 7.5l 460 cid can anyone help
06-19-2010, 04:49 PM
on
It will depend on your GVWR and the trucks gearing...what does your door plaque say
06-19-2010, 05:11 PM
on
the gvwr is 8800 how do i find out the gearing
06-19-2010, 05:34 PM
on
Quote:
Originally Posted by
adrianm22
The easyest way is to take the number off the axle tag that is afixed to one of the cover bolts. Go here, and punch in that number, your front number will be 7 didgets and look something like mine 610312-4...I just remembered that the ratio is stamped right on the tag, example 3.55...so forget the link for now
The Expert Dana Holding Corporation Part Identification for Driveshafts, UJoints, Spicer, Dana, Drivelines
GCWR
ratio max
3.55 11,000 lbs
4.10 11,000 lbs
4.10 16,000 lbs (I asume a fifth wheel from here down)
4.63 28,000 lbs
5.13 26,000 lbs
06-19-2010, 05:52 PM
06-19-2010, 05:55 PM
on
ok my tag says L551027802 and then V127C
06-19-2010, 05:58 PM
on
Is there a chance that the "L" is really a "3"?...thereby giving you a 3.55 ratio
06-19-2010, 05:59 PM
on
ok its a c9 the capacity is 6250
06-19-2010, 06:00 PM
on
06-19-2010, 06:09 PM
on
ok with nowhow do i figure my GCWR
06-19-2010, 06:10 PM
on
It' already posted above
06-19-2010, 06:12 PM
on
Conanski
much easyier, if same as shipped
06-19-2010, 06:13 PM
on
oh ok so 11000lbs is my GCWR. right thanks for the help
DieselVol
1999 to 2016 Super Duty
39
03-23-2012 11:34 PM
RCrawler
09-28-2006 05:58 PM
penguin149
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-02-2002 11:11 PM
ChrisMorlan
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
08-30-2001 07:36 PM
Nathan
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
02-13-2001 08:29 PM
1990 ,
96 ,
chart ,
dana ,
diesel ,
econoline ,
f350 ,
f450 ,
ford ,
gcvr ,
gcwr ,
v127c
