Need a bed liner for my 2011 SD. What brand?
Forget the bedliner. Get it Line-X'd. I had a Ford bedliner on my 1997 F150 and it faded. Looked like crap. On my 2006 F150 I got the Line-X. Looks much better. On some drop in bed liners, if any water gets trapped underneath it could cause corrosion. Water always needs somewhere to drain.
LineX or Rhino, drop in liners move around and rub through the paint on your bed, if you don't want a spray in I would opt for a simple rubber mat in the bottom rather than a plastic drop in, after the drop in is in your truck for a year the whole bottom of your bed will be worn down to bare metal.
Bringing an old thread to life.
For those of you that have the integrated rear-step, are you leaving the plastic on the tailgate and only doign the bed? Or is it possible to have the tailgate sprayed as well?
my truck had the step, and I wish it didnt. I'd much prefer to have a flat tailgate.
I had Line-X in my last truck, have Rhino in this truck. I liked the Line-X better. Both are well worth the $400-$500 you can expect to pay.
I plan to do this mod at some point, I hate the way the bedliner is designed with the pole on there.
Here's the link:
https://www.ford-trucks.com/forums/1...sist-pole.html
