I have a 2003 E150 Chateau with the 5.4 motor, tow package and 143k miles. I recently purchased this van for towing a 4500# travel trailer which I took on a successful, no mechanical issue, round trip to Yosemite N.P. The problem, only 7 mpg average..... is this what I should expect or is something wrong with the van; a needed tune-up maybe? What could I expect with an older model with the 460 or a newer V-10? Any help would be much appreciated.
Rich
Hey there, I been hanging out here for a while and checking out the forum so I'll just jump right in.
I believe the complaint is the MPG not the performance of the 5.4L.
My first question is how fast were you driving to get 7 MPG? If you were driving 70 or 75 like most people do you really cant expect anything better. Drive 55 -60 on the flats, in the hills, drop a gear and keep the RPM where your torque is right around 2500 RPM and see if it makes a difference. Oh and turn on your flashers.
I can tell you by experience that 55 will get you near killed by truckers who like to run up on you fast to intimidate you then cut back close when they come back over. I think I got 13 with my 5.4 15 passenger towing a Mustang on a car trailer through the mountains of East TN, it felt like I was holding it back so I let it go, did 70 without issues, I held it back to 65 on steep grades tho.
Rich
So, back to your question. I think you should be doing better, but how fast are you driving?
I have a 2008 E350, 5.4L, 4R75 trans., 3.73 rears and 265/75 16 tires. This weekend I pulled my 2500# pop up (10,500# GCW) @ 13 MPG for over 600 miles driving 55- 65 MPH depending on how much room there was, up and down some huge hills in British Columbia (8-13%). I left it in cruise at 60 on the biggest hills with the engine at 4-4500 RPM. Maybe you need a tune up.
I have a 1990 Falcon 190 Class B camper van with a 351w, it's heavy. I have been pulling a 14' enclosed trailer and getting about 10.5 mpg. I changed the gearing to 4.10 and it it improved the mileage. Generally, you need to run close to the peak of the torque curve for efficiency. I tow in OD but I change my tranny fluid and installed a cooler. I want a tach and a tranny temp gauge. I have a thread here on my diff swap. I may swap again for deeper gearing and dually's so I can pull a bigger trailer.
It looks like the 10.5 mpg towing the trailer was a fluke, I'm probably closer to 8.5 mpg over the long term. My van is heavy, very heavy. I still think the gearing change helps more than hurts and if I find the right deal on 4.30 gears I'll grab them. Tires rated for more weight would make me happy too.
I respectfully disagree with your comparison. Towing a pop-up is a lot different than a travel trailer. Having towed a 3,000 lb pop-up from one side of this country to another, I can tell you there's a load of difference between the two. The biggest difference is in wind resistance. You don't have near as much drag on a pup as you do with a travel trailer. The pup rides mostly in the slip-stream created by such a large tow vehicle. A travel trailer will be slightly above the height of the vehicle and thereby catching more wind drag.
That said, 13 mpg with your pup is pretty good. I only managed about 14 with the 1/2 ton truck I towed with at those same speeds, but lower RPMs. I also agree with your comment that a tune up may be called for since 7 mpg is less than what I average with the V-10 and 6,000#. I manage between 8-10 mpg unless I'm going through some steep grades (ie US 65 south into Branson, MO) and then I'll drop into 7-8 mpg.
What kind of MPG do you get driving around town without towing? I just ordered a 2011 e-350 xlt with the 5.4 V8. I'm wondering if i shouldn't have ordered the V10 - it might not be too late to change the order. Our main use is daily driving, but I do plan to buy a travel trailer and tow with it in the not too distant future.
I think the fuel mileage around town - which would consist of 90% of my driving - will just be too bad with the V10. My hope is that the v8 with its LS 3.73 rear axle will be quite a capable tow vehicle when the time comes - keeping in mind the 6700# towing capacity of the van.
Not sure about the city mileage since most of my driving is mixed. I usually get 14 or so in mixed driving. I did have it out and about St. Louis last summer and even though there was a lot of stop and go driving, I still managed 13 on that tank of gas.
FWIW:
My 2008 5.4 gets 11-12 in mixed driving, 16+ floating down the Interstate and 10-11 stop light to stop light. I do have fairly aggressive A/T tires though. I imagine that LTX M/S2's would really help.
As for the OP, my tractor trailer gets better than 7 MPG averaging 65,000#.
