92 ford sagging a bit up front
Old Jun 22, 2010 | 11:07 PM
Molineguy's Avatar
Molineguy
Makeos, might want to do some more checking on here if no one replies, the Moog 844 spring off a 250 2wd will raise a 4wd f150 1 1/2 -2" according to what I have researched on this site and that is also what the local guy at the alignment shop thought. The 3/4 ton spring is going to make it ride stiffer, but for me thats fine because I am always hauling or pulling stuff on less than ideal roads. I don't know for sure, but from what I have read in other posts, you might be better off putting spacers under your springs to raise it a bit and you would keep your ride it has now. Thats just my 2 cents, there is guys on here who really know there stuff who could give you better advice. Like your truck, that is clean and straight as they come.
Old Jun 23, 2010 | 11:13 AM
J1nx93's Avatar
J1nx93
Originally Posted by TexasGuy001
Thanks, I really like my trucks color scheme. A nice truck is a nice truck regardless of the color, unless its hot pink. LOL...
Yeah, the 844 is the spring alot of guys on here are running.
What are you talking about? Pink is the manliest color you can get on a truck.
Old Jun 23, 2010 | 11:14 AM
BCHauler's Avatar
BCHauler
If you do a part search for a same year 2wd f350, you will get the correct springs. The Moog part # is cc844. Those are what I installed. Many folks on here have used the Spicer springs but I don't know the part# for those.
Don't sweat the stiff comments unless its really important to you to have a soft ride. They don't make the ride uncomfortable, in my opinion. Because so much weight sits on the front of these trucks, a stronger spring has less of a ride impact in the front than in the back. I've made this comment in a number of other threads, but I live in an area with potholed paved and gravel roads and the ride doesn't bother me at all.
I'd buy some (maybe even junkyard), put them in (its really easy) and then take it for a ride. If you don't like it, take them out and return them. You don't have to do the alignment immediately.
Old Jun 23, 2010 | 04:04 PM
makeos's Avatar
makeos
I've seen that those springs do work on 4x4's but haven't seen any real answer about on a 2wd. I will look up those moog springs though. Thanks.
jg09
Oct 21, 2013 10:42 AM
Smokey01
2004 - 2008 F150
23
Mar 11, 2010 02:23 PM
mongo75
26
Jan 13, 2010 08:49 AM
leisjohn
Appearance & Dress-Up
Jul 19, 2003 09:40 PM
