1999 7.3 f350
Welcome to FTE!
Did this just start occuring or has it been doing it for sometime? Do you run a chip or programmer? Stock trans?
THis problem started about 90 days ago but has gotten worse and now it has got were it really hits hard. No chip, and stock trans
Sometimes high-mileage trannys get a sticky, erratic line pressure modulator valve.
From how you describe your symptoms, take a look at this:
http://www.sonnax.com/instructions/96948-01K-IN.pdf
It's simple to install, cheap, and might just cure what ails ya'.
If you decide to go this route, also consider doing this mod, too:
http://www.sonnax.com/instructions/36948-18K-IN.pdf
Pop
Pop
