Firestone Ride Rite Air Bag Install (minor issues)
I ordered a pair of Ride Rites from JC Whitney for an early fathers day present for myself. They arrived today and I hoped to get them installed tonight. I got the drivers side done so far, but not without some minor issues.
First, the jounce finger (part of the block) that the lower bracket installs over is wider than the bracket so it won't slide up against the spring. Not a big deal but a pain when laying on your back with a 4.5" grinder spraying sparks all over yourself, not to mention the 44 gallons of gas nearby.
Second, I started the passenger side, but will have to loosen or remove the Helwig to remove the large plate/shock bracket because the lower bag bracket wont slide in with it there. I think it will be ok once I get the bag bracket on, but it had to come off anyway to do some grinding on that side.
Third, my arms are a little short. Wrenching, fitting, grinding, requires the use of a lot of muscles that I'm sure will be sore tomorrow.
Fourth, I had no help. I would recomend help.
Overall not bad so far, I may be a little whinney because i'm tired and didn't get it finished like i hoped.
All gripes aside, it is a nice kit. I'll let ya know how tomorrow goes.
Dave.
Dave.
Been there, done that. I agree with everything you said but I was able to get the passenger side on without taking my Helwig Rear Sway bar apart. Like you said, a was also a little nervous with grinding off the jounce bumpers with 44 gals of gas right there. Haha. But after all is said and done, with 1300lbs of trailer tongue weight, you'll really like them. Good Luck
Been a while since I've been on FTE and realized I didn't follow up this thread. Love the air bags! They are the icing on the cake to top off the rest of the mods. I run them at 30 lbs. when pulling our travel trailer and they make the truck feel very stable in the rear almost to the point you forget the trailer is back there. Very pleased!
DaveandJennyP, I'm not sure if you have a controller hooked up to your system, but we offer a few options, and a couple of them are wireless. Having the adjustability of air springs is great, being able to adjust on the fly is awesome!
golfmedik, if you have any general questions, you can shoot me a PM. Or I can find an Air Lift kit for your application.
Another newbie question from me guys I've only had my Excursion a week or so, and haven't towed anything yet - but my truck has standard springs and they look like the same ones that have been fitted from the factory
I've been reading about people chaning the leaf springs front and rear, and that's what I was going to do, as I want the truck to handle better on the road, and my TT has a lot of tongue weight, so I want something to level it................but wondered how hard the ride would be when I'm not towing
Would these air bags work well for what I want? Would I still be better changing the springs, then adding the air bags, or just add the air bags front and rear, and have low pressure in for road driving, then increase the pressure when the TT is on?
ngng
6.7L Power Stroke Diesel
16
04-10-2019 01:59 PM
hpcbmw
32
09-30-2016 09:59 PM
ruschejj
41
07-07-2015 09:45 PM
l8000
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-31-2014 11:19 AM
