6.0 Ford Rant
Yeah, what the hell. Damned 6.0's. Why should I have to deal with 195,000 trouble-free miles? When my EGR valve clogged at 160k why the hell did I have to spend $4 on gaskets, a used tooth brush,a nd a bottle of carb cleaner to get it functioning properly again? Why hte hell is that the only real problem these engines have.
Why the hell does the duramax not have any problems other than the egr, glow plugs, injectors, worse fuel mileage, they don't have real mirrors, and numerous electrical problems. I wish i had gone with a ford so i wouldn't have to deal with just that little egr issue, because all those issues are so much easier to deal with!
duramax can lick my *****. I'll keep my 6.0 thank you.
Even though the vast majority of shops are no doubt both honest and competent, it only takes a few to generate a huge "bitter taste" (and a lot of forum posts).
Oh, don't get me wrong.....I've had other Ford trucks in the past (gasoline-powered) that were just fine. And, I ordered an '11 Shelby GT500 back in May. So, I am a 'Ford' guy. However, I'm extremely disappointed in the truck I own now.
Unfortunately this is more common than it should be. That is a BIG reason why I always preach gauges and go out of my way to write-up simplified troubleshooting tips. If you can do the simple things yourself and then troubleshoot the other things so that you have a good idea of what the issue might be - then you can somewhat protect yourself from shops that are just going to "change parts" at your expense (whatever their reason would be to do so).
You did have an aftermarket air filter (not quite by the book) and even took it to the dealership that way. Maybe it shouldn't have made a difference, but when a dealership sees that you have aftermarket mods (and maybe suspects you have more), it can affect the type of work you get. Not saying that is what happened, and definitely not saying that it should have happened ..... just saying some folks are like that. Especially if you get angry at them, etc.
on
Let me ask you this and please be honest. Did you get the 6.0 with any preconceived notions about diesels? Particularly thinking that this diesel was like the diesels that came before it?
It is well known that most gauges that are out there from the factory, no matter the brand or model vehicle, are crap. It's just been an accepted fact. I have been burned by two vehicles because there wasn't adequate information being shown on the gauges. Should that be the way things are done, that's for another debate. In all honesty, the money that was spent on the a/m intake would have been better utilized with gauges, but hindsight is always 20/20.
#28
#29
#30
I've had pretty good luck with my 6.0L. Only problem(s) Ive had with it were, 1.) was a human error (someone at Ford Dealership forgot to attach my tranny fluid tube to the tranny so my tranny overheated when i was hauling horses and 2.) just recently its been lurching but Ive been told its dirty injectors?
And I only have 60k miles on it, and I haul with it most of the time and its decent enough!
