parking brake pedal
parking brake pedal
Hi all,
My parking brake pedal has no tension anymore. Went to apply it a while back and I just about put the pedal through the floor, and it felt like something broke loose. Looking at the parking brake pedal assembly, it looks like a spring that may provide tension is broken. Anyone else had this problem? I am assuming that I will need to replace the in-cab assembly, so where is a good place to pick up a replacement at a decent price?
Thanks, Steve
Here's a pic by camodown that shows the e-brake shoes with the rear rotor removed. He was doing axle bearings
and while at it replaced his e-brake shoes.
The tension that pulls the pedal back up is the cable from the parking brake. If the cable breaks, then the pedal will stay at the floor.
Mine broke the button off the cable right at the end of the parking brake pedal. If that is what happened to yours, it means replacing the front section of the parking brake cable.
As mentioned above, contact Ed and he will be able to fix you up with what you need.
I just broke the front cable today (button popped off of the cable)
I purchased a new one to install onto the pedal. Question is, how do I install the cable? Do I have to pull the ECM? How else do I access it? Can you give me some tips onto where it attaches?
My Chiltons was not helpful at all :-(. I am fairly mechanical, so that won't be a problem.
BTW, this is my first post. I have been a lurker on here for quite a while. I just bought my first truck, and I love it.
Thanks,
John
2000 Ford F250 7.3 diesel 122K miles RWD
Thanks,
John
Thanks,
John
Thanks,
John
Happy first post !!! and welcome to the non-lurking side of the forum
Robin, IOT understand which way to tighten the star wheel adjuster, you need to tell us, is this the right or left rear wheel that is shown here.
Thanks big guy.
Thanks,
John
Thanks,
John
Yes, you do have to remove the PCM to change the front cable. Then you have to pull it down thru the floor from the outside. To get it hooked back up you will need to unhook one side of the cable in the rear where it splits to each side, to get enough slack to get the front section hooked up. Then re-hook rear cable.
Since you are mechanical, you shouldn't have to much trouble, it just takes time and being flexible to get that front cable changed. The important thing is unhooking the rear cable, or you will never get it back together.
