This weekend's project, turbo mods off to a good start
#76
Mine makes a similar noise WITH the ported housing if I get off the pedal at full boost. Now, you may have been racing turbo CARS, but diesels are different because there is no throttle body. True surge is when the turbo is under load & stalls. When you let off the pedal, the drive is greatly reduced, and so is the force on the shaft. The sound of the air is the same as it exits back out the way it came, but there is no (or very little) drive on the exhaust side. Exactly how is one to "fix" that? The air MUST go someplace....
Not trying to sound like a smartazz -- sorry if it sounds that way....
There comes a point where you need to figure out boost, what a/r you need, how much your turbo flows etc to figure out a perfect scenerio. Which is hard to do.....running the Motec on the drag car i monitor EVERYTHING with more pressure sensors then you can ever find and its still hard to get equal. I was just stating that the OP's truck definitely is not acting normal. On a side note without looking at his vids, what boost was he hitting when its doing all that noise when letting off?
#77
Oh, so you did what quikkordead did? I see... yeah, I was just gonna screw it in all the way. From the last post I read, the stock Garrett is only good for 25psi? Where'd you get those specs, BTW? I just don't wanna kill the turbo... I guess I've said that several times. I just would like to fix my lag... what would y'all recommend MAX boost to be? 25psi? That's kinda what I'm thinking...
#80
on
van turbo has a 115... it will help build a little more boost....but the main thing it does is makes it spool a little faster...if you want more boost you need more fuel and a turbo that can take it..a stock turbo just doesnt push enough air...a 38R is 1 to 1 at 30 psi but its also flowing 33% more air then the stocker....boost doesnt make power..air does...corse more air means higher boost...
#81
Right, all I want is quicker spool-ups... so, just tinker with the rod until I can hit and/or stay under 25psi?
#83
You shouldn't make much more than 25 anyway with a WW on it. I was hitting 26-27 with the stocker & WW tops. That's my experience, anyway.
And the wastegate doesn't "blow off" boost. It opens and lets some of the drive pressure around the exhaust wheel instead of through it. Maybe I'm splitting hairs here, but it's totally different that a "blow-off valve" that seems to be described above.
FWIW, I'm getting 36-37 psi out of my van turbo right now & about 450 rwhp. Been that way for better part of a year so far...
#85
#86
60RatRod
16
01-06-2021 10:19 AM
Craig46
1947 and Older Ford Trucks
35
12-19-2015 02:16 PM
Excurvelle
02-16-2015 08:18 PM
