6.0 won't crank
#61
Either an open circuit in the START circuit (unlikely), or the PCM failed to "see" the transmission in PARK or NEUTRAL and therefore, failed to ground the starter relay to complete the START circuit (more likely), when you attempted to crank the engine over with the key.
Are there sensors that need to be replaced? And where are they?
Thank you.
#62
I suggested you look at the ICP and I can't tell if you did. The earlier description of the location of the ICP sensor is not very good - since you have a 2003, it is under the turbo, not the alternator. Did you find it?
#63
#64
Well the original thread was from a few years back.... 09 I think It just has been hijacked a few times.... it looks to have a lot of good info.... mchan and cheezit don't steer you wrong..... but yeah it has the fixes for several vehicles... the only thing that sucks is we never hear back with results.... I think that truck may still be waiting on the pin test on some farm somewhere.
#65
You really should start a new thread solely on your problem. In that thread you need to state what your problem is (underhammersdotcom already asked what is the trouble), the symptoms, what you have already investigated, and your truck specifics (what year your truck is, any mods, what things have already been repaired on it, etc).
And yes I did find the ICP but was told by the local Ford dealer mechanic that a faulty ICP will not disable the starter as is the case with me, so I left it alone.
I carried out most of the tests suggested by you and others (fuses, relays, thick yellow wire which produced no cranking when touched to positive post of the battery) in addition to other tests I may not recall now.
Please point me to a diagram depicting the location of the aforementioned pins 6 and 13.
Thank you,
#67
The batteries are fully charged.
Wouldn't the solenoid be clicking even if the starter had gone bad!?
Or do they both go bad at the same time?
Thanks.
#68
If the solenoid isn't even clicking when you jump the male end of the jumper wire to the battery positive terminal, the solenoid itself is bad (which is all purchased with the starter anyways) or there's an issue with the wiring to the starter 's' terminal.
#69
I decided against starting a new thread because the wealth of information and continuity available in this thread will be very valuable for someone else who will face the same problem.
Thank you,
Thank you,
First I have heard of a bad starter causing a P2285 DTC also ....
#70
Just to be absolutely certain of what I am understanding. please give me the size of said yellow wire.
The one I found and used was not overly big.
Thanks.
Thanks.
#71
#72
ok first off check the dlc connector for power and gorund.
next check resistance between pins 6 and 13 on the dlc connector. it should read 1 of 3 things
0,60 or 120 ohms. you want 60 (or very close to). anything else means something is off line.
check fuse f2-22
check power and grounds at the pcm relay you should have 2 of each.
check wire harness and fan clutch for damage.
if this fails repost. with findings
check fuse f2-22
Furthermore, which pins are for power and ground on the DLC connector?
Thanks.
#73
Sadly resistance between pins 6 and 13 is 0!
What does a closed circuit mean in this situation?!
#74
What about pins 6 and 14? What readings do you get when you ohm out those two? Do you get 60 ohms or 120 ohms? And pin 16 of the DLC should have 12 volts to it, regardless of ignition key position, not only on this vehicle but ALL vehicles model year 1996 on up to current model years that are OBD-II compliant.
#75
The voltage between pin 16 and the metal plate behind the DLC is 10.2 volts
(As I don't know which pin is ground on the DLC).
Both batteries read 11 volts during the tests.
