Trying to figure out the lock mechanism on my new altmans....
Just got them and started playing with them. They do not appear to lock like the old ones.
Am I mistaken or didn't the old locks, lock by using the handle on the inside?
Then the next question is how do the electric locks work? with the altmans the actuator would have to push out with one pulse and then pull back with the next. Is that how typical door locks work???
Am I the only one that find this really annoying??? all parts supplier that tell you how incredibly good there parts are but forget to mention these little details that becomes really annoying.....
Just received a set of original altmans easy latch after have been doing some Web research on the subject and this fact jumps up and bite you in the ***.
It even states on the Web to be a complete bolt in replacement of the old poor design.
Well, that poor design could be locked from inside. Despite having other weaknesses
I just had to rant about it. It's not the first time and probably not the last I am afraid
We are sorry if our descriptions are not clear enough, we wish it locked from the inside too, it is beyond our control though.
Hello, we are sorry about your frustration, if you a referring to us, on our website it says "Uses stock door handles inside and out, and stock outside key lock." and also in all of our catalogs it says "Uses stock door handles inside and out. Even locks with stock outside key lock.! (Inside handle does not lock door) "
I didn't check the catalog, unfortunately
Well I guess I just haveto be creative.
But I am starting to get more and more suspicious when it comes product specifications, especially when it comes to "what has been left out"
I also bought a set of the original ones and found out later that they weren't going to work with the original handles. Kind of a pain since you either have to install electric locks, fabricate up some new linkage or you can dish out and buy the cylinder block and lock cylinder to install a lock in the drivers door which still needs to be locked from the outside. I think the electric locks are the easiest and if they fail you can still get in through the manual lock on the passenger door. I hope....
reamer
40
01-17-2005 05:36 PM
