Transmission flush- anyone done it?
I have an 01 F150, 5.4 with about 36,000 miles and I want to flush the tranny. Anyone done it themselves?
I've read the tech article on this board and watched them do it at Jiffy-Lube. It looks pretty straightforward. Anyone know of any problems to look out for or helpful hints?
From what I can tell at Jiffy-Lube the machine they use is not really needed. It looks like the machine is used to store the new fluid and it also pumps the old fluid thru a display window, so you can see you're getting your moneys worth, before sending it to the recycling container.
Thanks
Tim
Thanks
Tim
couple of transmission fluid changes ago i paid about 5 bucks for a low and wide plastic container from walmart. ( i think most people use them for storing clothes). Roughly 6 inches high, 3 feet across and 3 feet long. changed the fluid without spilling a drop. Also handy for radiator flushes.
