Rocker shaft end plugs
Yeah.....I just said *&%^-it and ordered 2 new rocker shafts and new tubular push-rods from JM today!!.....
AND at his suggestion, I'll drill and tap one rocker "stand" on each side for the 1/8" (hex) pipe plug that will replace the oil drain tube to pressurize the rocker-shafts.....
I also ordered a new Holley 0-8007 390 CFM carb!
I'll also order the Holley TPS kit for it soon.....
The tube does not "drain" though.......
The tube is in a hole on top. So the oil comes in through the bottom and is pumped in until the tube fills up.
Gravity permits some of the oil to seep into each rocker. Excess oil overflows out through the drain (copper) "tube".
There's no reason to have a drain tube.
Pressurizing the hollow rocker shaft will only cause more oil to be pushed into the areas that you want lubricated anyway. ALL the oil that is sent to the rockers shaft, will leak out of the lubricated parts and drain out of the head......... there's only 1 drain at the end of each head where the tube is anyway.........
This is why most Y-block "experts" remove the drain pipe and "pressurize" the shaft.
You could just pinch off the drain tube if you weren't going to disassemble it but mine is already disassembled.
There's no reason to partially pinch the tube. Just use a pair of "vise-grips" and crush the end.
Since mine is already off, I'll put hex-plugs where the tubes were....
Cheers,
Rick
I don't want to butt in, but those so called drain tubes DO serve a purpuse and should never be completely pinched off or removed. The right front tube directs oil to a valley channel that feeds oil splash to lube the timming chain. The left rear tube does the same at the rear of the valley to lube the distributer/cam gears. Tom
Oil to the chain from the valley can only pass through the two holes at the front of the block, which are well above the floor of the valley, meaning to me that it can only be in airborne droplet form, thrown about by the gears and valley hardware. I think most engines are mounted so that they point slightly downward in the back from horizontal, so most oil in the heads with plugged overflow tubes will exit rearward. With overflow tubes the one in front will drain into valley and migrate rearward also.
Airborne oil can also access the chain from beneath. So...I think I will be plugging my overflows.
Thanks for bringing this up. It made me get off my butt and really take a look at the block and heads, as I have heard this argument against pressurizing the shaft for quite a while. Mike
Mike,
Take a look at a bare block. The front of the valley has a dam to prevent the oil from draining back down the valley. It is high enough that the oil will drain out the holes at the front of the block.
That being said, if you've ever had the valve covers of, you can see that oil is everywhere, so it gets around one way or another. Same with the valley cover. I'm sure enough oil is flung to all the right places. Because of the incline of the engine, the distributor gear absolutely gets enough. For the timing chain, you got the oil from the front main being flung everywhere.
This seems to be supported by the number of people who pressurize the shafts without any issues.
Mike,
Hi Tom, You're not butting in at all!
I'll agree with you that Ford originally put them there for that purpose. The Y-block guy I asked about this told me that it isn't really necessary because the timing set is still well lubricated by splash oil. (the dist gears will still get oil from head run-off) Later SBF engines lube the timing set exclusively from splash.....
I even asked Mummert when I ordered the new rocker shafts and pushrods last week and he told me that it's a good idea to pressurize the rockers like I'm doing.......
I am thinking that it's really not going to be a problem.....
FordTruckFan01
Modular V8 (4.6L, 5.4L)
06-21-2017 10:00 AM
