52 F1 clutch problems?
Hello everyone, I have a 52 F1 with 239 flatty and 4speed trans. I was wondering if anyone knows where the release fingers are supposed to be, "straight" or have a bend in them. I noticed that only one of the three fingers on mine was barely touching and the other two were not, so I pulled the tranny and measured throwout/release bearing and measures about 3 1/4" for surface contact. Is the throwout bearing just the wrong size or did for sum reason the fingers get bent all the same? It looks to uniform to me to have all three fingers bend the same angle and amount? Any help would be greatly appreciated.
Help is on the first page of the forum, right at the top:
https://www.ford-trucks.com/forums/6...-pictures.html
Here are 2 pictures I took, one with the pressure plate apart and one with it together, was going to try and straighten them.
tn on Flickr - Photo Sharing!
tn2 on Flickr - Photo Sharing!
NAPA sells both a Long-style (fingers) and a diaphragm pressure plate for the 10" clutch, but I think they only have a Long for the 11" which is what I suspect you have. The diaphragm is smoother, may need to check clearances to bellhousing, but I've had one for a couple years. If you have a 10", I'd consider the diaphragm.
If there is a truck clutch shop in your neck of the woods, they can rebuild it. With your fingers being toast, I'd make sure they can get new ones first.
cradduckj
17
05-05-2014 07:03 AM
Dwinn
09-05-2013 06:27 PM
76250_4x4
12-29-2010 03:41 PM
F150Lariat79
09-13-2004 08:40 PM
