'90 F150 5.8 no spark
Guys, this is driving me nuts. A buddy came up to go fishing and his truck died in the Burger King drive thu just like he turned off the key.
No spark at all. Test light is solid (no flash) at the tach lead on the coil.
Ran through all the troubleshooting steps in the Haynes manual and everything checks good - with the exception of not having any spark
ICM checks good at O'Reilley's and all voltage to the ICM checks good.
Coil checks good and I tried one off of another motor as well.
No spark with or without SPOUT jumper.
Voltage for PIP and SPOUT at the ICM connector check OK also - although with a digital meter the readings do jump around quite a bit.
No codes other than some EGR codes (62 and 33)
From what I could find on other threads it looks like the general advice in these situations is to change the PIP.
I've got the PIP and am getting ready to put it in - any other suggestions to check in case that doesn't do the trick?
Thanks!
Branden
Thanks!
Branden
Thank you! My buddy and I both have more time than money so I pulled the distributor out of a rebuilder motor I've got and we'll put the new PIP in it and see what we've got. I could just try the other distributor, I suppose, but I'd much rather use good parts than unknowns for testing.
Thanks again for the info!
Branden
Branden
New PIP installed and same problem - truck's deader than a hammer....
This is truly aggravating since everything else tests good.
Any way to take the ECM out of the equation to see if it's a problem with it?
The only other thing I can come up with is that the parts store misdiagnosed the ICM as good but I doubt it since it's a simple check.
Pull the SPOUT connector. That should take the PCM out of the equation. The ICM can be a pain to test, but the testers at the stores are usually pretty good. Assuming the parts counter jockey has some idea of what they are doing.
If you do the momentary grounding procedure, that eliminates the PCM for sure. If the grounding does not work you are missing something very basic such as voltage in, and a path to ground.
Artaxerxes
13
08-17-2020 07:03 AM
1black150
04-28-2018 04:47 PM
hogryder007
17
07-27-2016 04:54 PM
exidor12
09-13-2015 06:34 AM
swirk
07-23-2013 11:29 PM
