Guys,
Tried looking for the required additive for the Radiator this weekend. Hit all of the local shops (autozone, orielly's, napa) and no one had a clue what I was talking about. Where do you all get your additive and what is a good brand/maker? Hoping I was just too dumb to see it in the store so I don't have to special order the stuff. what do yo all run (DCA2 or DCA4)?
Diesel coolant additive,dealer has it for about ten dollars for a pint bottle are you can get the same thing at o,reilley,s for six dollars,the same thing,motorcraft.
If I read the other threads in the 99-03 forum correctly, the DCA-2 is a better adative because it only contains nitrates and not a mix of the moly####. The DCA 2 is easier to keep regulated and the nitrates are the best cavitation stoppers. is that right?
I oopsed in my earlier post. DCA-2 is what the VC-8 / FW-16 additive is. The DCA-4 is a different formulation. There has been many discussions on compatibility. Stick with the Motorcraft product.
