Oil filter tightening - how much?
Old 06-02-2010, 05:06 PM
SteveH-CO's Avatar
SteveH-CO
SteveH-CO is offline
2001 7.3; Motorcraft oil filter.
The Motorcraft box said "3/4 turn after gasket contact" - which left the filter stupidly loose. The sticker on the oil pan said "1.5 turns after gasket contact". The PowerStroke owners manual service booklet said "1.5-2 turns after gasket contact". I left it at 1.5, which felt good. The last oil change joint apparently turned it 700 times after gasket contact, since I had to use a 2' pipe on a now-bent/mangled CarQuest US-made oil filter wrench to get the old one off. I made a sheet metal 'liner' for the wrench to keep from crushing the filter, which was a good idea.
So - Ford has three conflicting suggestions - how many turns do y'all do, such that it neither vibrates loose, nor is so tight it cannot be removed in the future.
Thanks - Steve
Old 06-02-2010, 05:11 PM
binuya's Avatar
binuya
binuya is offline
I go tight as I can with just one hand. Usually it's almost a full turn just after it contacts the gasket. And, I lube the gasket well with oil. Never a problem with leaks or removal. I've always done all my vehicles like this and it works for me.
Old 06-02-2010, 05:23 PM
Bob Taulbee's Avatar
Bob Taulbee
Bob Taulbee is offline
Duct Tape Tech.
[quote=binuya;8957540]I go tight as I can with just one hand. Usually it's almost a full turn just after it contacts the gasket. And, I lube the gasket well with oil. Never a problem with leaks or removal. I've always done all my vehicles like this and it works for me.[/
2X that
Old 06-02-2010, 05:29 PM
frdf250's Avatar
frdf250
frdf250 is offline
[QUOTE=Bob Taulbee;8957589]
2X that
x3 on what they said
just remember, too tight = broken
Old 06-02-2010, 05:56 PM
Joelong258's Avatar
Joelong258
Joelong258 is offline
Too tight also means a pain to get off!
Old 06-02-2010, 06:04 PM
SteveH-CO's Avatar
SteveH-CO
Thanks - I think I'm ok this time with my 1.5 turns, but will follow your instructions next time.
Old 06-02-2010, 10:07 PM
Polkster's Avatar
Polkster
Polkster is offline
Plenty of advice in this forum on oil filters. Just wanted to add a suggestion i have read here. Poke hole in bottom of filter and drain before removing filter. Saves lots of spillage.
Thanks FTE!!!
Old 06-02-2010, 10:13 PM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
I have a habit of 3/4 to one turn after gasket contacts the block or filter adapter.
I use a Sharpie pen to index the filter and to gauge how much I have turned the filter.
I place a mark 3/4 before the final resting orentaition on the filter. When the
filter is in the proper orentation the mark is facing forward on the truck.
I also mark the date the filter was installed - since I have a pen with me.
bismic
09-02-2022 04:44 PM
Boaterguy
6.7L Power Stroke Diesel
04-10-2016 05:32 PM
cordts
06-28-2015 05:33 PM
Long Haul
1999 to 2016 Super Duty
45
11-02-2014 12:43 AM
FordmanNJ
03-23-2014 07:05 AM
Quick Reply: Oil filter tightening - how much?
