5.4L SD Supercharger Project
That has more to do with matching the supercharger to the engine. A centrifugal supercharger is a positive displacement charger, just like a roots blower. Most don't provide a lot of bottom end boost because they are small and not driven fast enough at idle to make a difference.
Been doing some reading on this. There does seem to be a lot of options when it comes to roots style blower on a 5.4L for 2V, 3V and 24V heads. Also, there are a few companies making high flow 2V aluminum heads. I guess it just depends on your budget.
One thing does puzzle me a bit. What is a 24V engine, anyway? I have a 3V engine. 3X8=24, so what is the difference between a 3V engine and a 24V engine?
04–07' FORD 5.4L 24V PROCHARGER SUPERCHARGER SYSTEM
. I was just wondering if it is a different engine from the 3V 5.4L engine.
No, not picking on you. I find a lot of references on the internet for 24V 5.4L Superchargers, like this one:
I was under the impression the only 4v headed 5.4 was natural aspirated in the Lincolns. The 5.4's taller deck makes the intake manifold wider than the 4.6, so the 4.6 blower manifold will not work. This is where my research years ago led me.
I'm using Delta Forces (used to be call Sniper Inc)'s Special Forces software to write my tunes and their interface to upload it.
My thoughts on off-the-shelf would be to talk to kene bell and see if they can piece together an f150 5.4L lower manifold, a drive and then the v10 plenum+out. My thought is that they only make one drive case per displacement, so the 3.2 (or whatever your choice is) is the same drive for the 4.6L mustang and the v10. The difference comes in at the manifold to head and the plenum dump location. The little stuff like the intercooler's radiator, pump are probably the same, but may have different lengths tubes.
I'm pretty sure there are aftermarket companies out there that have adapted plates to mate 5.4's to 4.6's and vice versa. At least head/intake wise...
Another way to go, instead of going with multiple valve heads is to get a set of Trick Flow 2V heads.
Trick Flow® Twisted Wedge® 185 Cylinder Heads for Ford 4.6L/5.4L 2V - trickflow.com
So after further looking into this, it may be in my best interest to build a 6.8L with a whipple and drop it in old blue. My thoughts are there is a larger aftermarket and more off-the-shelf parts. I don't really want a V10, because I know I can do more with 8 holes than most do with 10, but idk anymore. Thoughts?
Or should I just shelve this whole project and shoe horn a built 460 into the truck? I believe the 460 would be the cheapest route, but I don't know about compatibility issues
